1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
KCIR today-new PB-13.158/104.1-it's time to tune it!
Old Nov 28, 2006 | 06:29 PM
  #41
t6378tp's Avatar
Turbo 3.5
Originally Posted by grey99max
That was his old car(s), betcha... He's got a 3400-stall converter now... Most serious folk seem to do a TC mod.
yes it was, that's why I figured it was too late for you
Old Nov 28, 2006 | 07:01 PM
  #42
grey99max's Avatar
LandShark has Cosworth
It's never too late - I'm planning on a custom plate saying " IRUN12S" once I score a slip in the 12s.......
Old Nov 28, 2006 | 07:15 PM
  #43
streetzlegend's Avatar
I have to agree with him on this grey. Jime only started using high stall TC with 3.5, when was on spray with 4th gen and 5.5gen, he launched from idle (i also had asked him for advice and he told me the same)
Old Nov 28, 2006 | 07:36 PM
  #44
grey99max's Avatar
Yeah, yeah, yeah - but if I can get this car to hook up when launching at 2800 straight into heavy spray, I'll be well into the 12s. I downloaded "cartest" and have been running different combinations, and 12.7s are doable - with 10" slicks.
I have the power - I don't have the traction - yet.
Old Nov 29, 2006 | 04:20 PM
  #45
t6378tp's Avatar
Turbo 3.5
Have you try'd spraying with a 50shot for the 1st stage and 100 for the 2nd
Since you already have the tc you are launching almost in the powerband unlike launch at idle. So maybe staping down to a 50shot will help get out the hole without traction problems and then go into a 100shot to get the party started
I remember in a old post you say traction was pretty good with the 50shot, sometimes less is better
Old Nov 29, 2006 | 05:27 PM
  #46
grey99max's Avatar
Yeah, I noticed that a while back - my 330' times weren't improved when going from a 50-shot up to a 75-shot on the first stage. Of course, I sprayed the 75-shot second stage while still in first gear, which helped what happened after the 330' mark. Going to a 75-shot /75-shot helped the rest of the 1/4 mile though.
It's like I need to use three different shots to launch and finish the quarter.... Maybe launch into a 35-shot, go into another 35-shot, then hit the 75-shot for the finale...
I wish I had good videos of the front of the car during the 330', but I travel alone and see very few people I know at the tracks. I really want to get cameras on both sides of the front, so I can see and hear what happens, but that's not simple or cheap.. Still working on that one, too.
Old Nov 29, 2006 | 06:12 PM
  #47
t6378tp's Avatar
Turbo 3.5
Maybe you could try 50 then 100, or 75 and wait till 2nd gear to spray the other 75 either combo will help with your traction problems
Oh and 1 other thing are your wheels and tires marked to see if you are spinnig the wheels inside the tires. I am just asking cause with my truck if the tire presurre is too low it happens to me
Old Nov 30, 2006 | 07:16 AM
  #48
grey99max's Avatar
I'm thinking about changing how I spray - since I've tried every combination with two stages and gotten nowhere, maybe three will work. When you're going for the 12s, you can't wait a whole gear before spraying..
If those tubeless slicks spin on the rim, I'd have flat slicks....
Old Nov 30, 2006 | 10:56 AM
  #49
I say you try bigger slicks first. I think you will have better luck with that. and just ignore the possible issue with gearing. just get bigger slicks and try it.
Old Nov 30, 2006 | 11:16 AM
  #50
grey99max's Avatar
I think I may need 10" slicks, but it will still cost $500 to try them. Bummer.
It's a b**ch having too much power to hook up to the track, ain't it?
Three nitrous stages could also be "interesting"... cheaper than 10" slicks, though..
Did you see this dyno run?
http://s48.photobucket.com/albums/f2...t=Dscn1457.flv
Or this bank of 4 pushbuttons in a box?
https://www.electronicsurplus.com/co...=1131517944178
Heh..
Old Nov 30, 2006 | 11:46 AM
  #51
Heh..
hmmmm i like the pushbutton. too bad i cant see pic of it though. how much power did you put down on the dyno, i forgot. BTW you suspension is infact stiff like u said, because i didnt even see the car move when nitrous came in. When I dynoed a 50shot, u could see the car jerk and the hood move. But i have soft springs (Progress) and GR-2.
http://videos.streetfire.net/search/...a356858a62.htm
Old Nov 30, 2006 | 07:33 PM
  #52
Nealoc187's Avatar
SLOW
Are you saying $500 for the slicks and a set of wheels to put them on?
You don't have too much power to hook up, there are alot of guys with far more power than you have who are hooking up just fine. It's just about getting it all to work together.
Old Nov 30, 2006 | 07:58 PM
  #53
grey99max's Avatar
1. Yes - about $330 for the 26/10/15 M&H slicks and 180 for the wheels... give or take..
2. When the nitrous hits, I lose traction. If I use more, I lose traction. If I use less, I lose traction. Once in a while, I hook up right and things are good. Mostly I don't hook up with the little power I do have.
3. I've washed the slicks with acetone before each run last time out. My best pass ever was with 18.5 lbs in the driver's side, and 22.5 lbs in the passenger side (forgot to check after taking off trailer). Yeah, things aren't working together, I guess...
Old Dec 1, 2006 | 08:26 PM
  #54
grey99max's Avatar
Just ordered more nitrous parts
I've just ordered a 6AN 16' nitrous racing line, the latest type of line, and a 6AN bottle manifold and 6ANx4ANx4AN Y-connector to feed the front solenoids.
This should reduce any pressure drop in the main nitrous feed line. Once installed, this should help me get ready for a dyno tuning day.
Old Dec 2, 2006 | 03:30 PM
  #55
t6378tp's Avatar
Turbo 3.5
I figured it was too late cause you already have the tc, and I am pretty sure your not taking it out anytime soon
Old Dec 2, 2006 | 05:01 PM
  #56
grey99max's Avatar
H*ll no..... I'll figure this out, too... the Edge rules. I'm going to make sure the nitrous flow from the trunk is good, then it's time for dyno tuning. Once I have a handle on actual power, then I'll know what to try next.
This is the fun part - then the "IRUN12S" plate is next.
Old Dec 2, 2006 | 06:16 PM
  #57
t6378tp's Avatar
Turbo 3.5
good luck when are you going back to the dyno, I thinking I will go in jan to check my a/f since I do not have a fuel pressure gauge yet.
Hey hopfully some-1 in your area will be dumping a pair of used 10inch slicks since the season is over and you can try them out for cheap to see if it will work
Old Dec 2, 2006 | 07:52 PM
  #58
grey99max's Avatar
Soon - after everything is installed and tested.
Actually, tire tests are over until next spring, when tracks in the Heartland open again.
Old Dec 3, 2006 | 06:48 AM
  #59
t6378tp's Avatar
Turbo 3.5
that sucks the track here will be open till next week then closed till jan., but in jan and feb it is only on sunday and weather permenting
Old Dec 3, 2006 | 07:02 AM
  #60
grey99max's Avatar
Lucky.... It's 16 degrees right now.
If I can get some serious numbers off a dyno tune, I could put my car on the trailer and take a long trip somewhere south of Kansas, whereever I find a decent track still open.. Of course, at 8 1/2 miles per gallons, a long trip can be expensive - I'd probably have to travel at least 300 miles - maybe 500, like to the Dallas area.... and then come home again.
If I get serious numbers, we'll see..
Old Dec 3, 2006 | 07:59 AM
  #61
t6378tp's Avatar
Turbo 3.5
The weather is crazy right now Dallas may even be out the of question. I think it just snowed there
I may try next week if not I'll wait till jan. I had to install a new straut and brakes. Then it's new plugs, tranny flush and cooler installed, up the shot to 75 and back to the track
13's here I come, but after that who knows I was thinking sc or maybe 3.5 swap cost is within a few hundred dollars but with the 3.5 swap I get a newer motor with about the same power as a sc'd 3.0. Well just some idea's to fart around with when my engine goes. Knock on wood does not happen anytime soon
Old Dec 3, 2006 | 08:07 AM
  #62
grey99max's Avatar
You'll need good tires when spraying at the track - but you know that, now.
My money is on the 3.5L conversion. Spraying a 3.5 will be ..exciting....
Old Dec 3, 2006 | 06:35 PM
  #63
Hoooper
12s would be killer, wish i was there.
oh and
Last Sunday, two new modified Z06 'vetts checked in, rumbling and shaking, and ran each other. I heard the times on the radio station, and one ran 13.04 at 106 and the other was 13.11 at 104.
theres something fishy about this, bad driver or something cause theyre much faster than that. ive seen a bone stock 2006 zo6 and it was running 11.9. plus, the previous gen zo6's ran into the deep 12s, maybe you saw the base model c6 running, but even that i would think is faster. either way good luck, you can catch them sooner or later.
Old Dec 3, 2006 | 06:49 PM
  #64
grey99max's Avatar
oh and
Yeah, I've seen Z06's run in the 11s w/mods and tires, but I'm just repeating what I heard the tower say over their track radio station. I saw and heard both 'vetts at tech inspection, and they sounded good - thought they were Z06's. Black and red 'vetts - yum. I parked next to one in staging, and there was a "402" badge on the right front fender ??? Just reporting what I heard - you can either "spectate" or "participate" you know.....
Old Dec 5, 2006 | 12:42 AM
  #65
Hoooper
i dunno what the 402 badge means, but never seen a Z06 with that on there, however ive never seen a corvette of any kind with that badge. id rather be participating, both in or against those cars
Old Dec 5, 2006 | 06:10 AM
  #66
NmexMAX's Avatar
dot dot dot ...
402 CID
Old Dec 5, 2006 | 07:11 AM
  #67
grey99max's Avatar
Originally Posted by NmexMAX
402 CID
Do you know what models of 'vette that came in? Just the Z06? This was the red one I was parked next to - and it had a loud, lopy idle... Not open exhaust, though.
I've put down a few BB vetts, and lost to many as well, but there's nothing like the sound of a big-block Chevy in the evening...
Old Dec 5, 2006 | 12:30 PM
  #68
Hoooper
402 CID
i know THAT, i meant i dont know of a corvette with a 402, not to say there arent any, just that i dont know
Old Dec 5, 2006 | 12:33 PM
  #69
Hoooper
o and the new corvettes run Ls7's which are just a variation of the famous 350. theyre small blocks, not big blocks
Old Dec 5, 2006 | 05:42 PM
  #70
NmexMAX's Avatar
dot dot dot ...
Originally Posted by My earlier post
402 CID
Did you try clicking the link (indicative of why it was udnerlined, because it was a clickable link), that will take you to a site where there is a Corvette with a 402 ..
Click the link next time. Here, it's a little easier this way, http://www.caranddriver.com/specialt...-corvette.html
Old Dec 5, 2006 | 07:31 PM
  #71
grey99max's Avatar
Well, they exist - I sat next to a red one for about 10 minutes, staring at the "402" badge on the front right side. And if that pair of 'vettes could only run really low 13's, then maybe I wasn't the only one having traction problems that day.... They did have street tires on - really wide ones, but street tires..
Old Dec 5, 2006 | 08:04 PM
  #72
Hoooper
They did have street tires on - really wide ones, but street tires...
sorry i didnt click the link, i thought you were just trying to be a smartass. that would have shown me the answer
What are the chances that a lingerfelter vette ran 13? i dont care what kind of traction issues they had, lingerfelter corvettes of old have run 7's. yes thats quarter mile. and the new z06's have 427s not 402's
Originally Posted by edmunds
The all-new LS7 of the 2007 Z06 reintroduces the 427-cubic-inch engine to the Corvette lineup. Unlike the previous 427 engine, which was a big-block design, the new 7.0-liter LS7 is a small-block V-8 – the largest-displacement small-block ever produced by GM and a tribute to its 50 years as a performance icon.
Old Dec 5, 2006 | 08:36 PM
  #73
grey99max's Avatar
Who said it was a new Corvette??? Or a lingerfelter 'vette??? I didn't see any distinctive badging on either car.... Just the "402" badge on the one I was close to...
Old Dec 5, 2006 | 09:58 PM
  #74
Hoooper
my bad, i thought you said it was a new corvette. and i said lingenfelter cause thats the link nmex posted. im not trying to argue here, just merely saying that the times they ran were a joke and maybe the badge was fake.
did the badge say z06 on it or just 402?
Old Dec 6, 2006 | 06:30 AM
  #75
grey99max's Avatar
"402" ...........
Old Dec 6, 2006 | 02:05 PM
  #76
Hoooper
"402" ...........
strange that it didnt say z06 anywhere on the badge. the z06's said z06 on the side with CID right under it, what year z06 was this?
Old Dec 6, 2006 | 02:40 PM
  #77
grey99max's Avatar
OK, for the last time, I sat next to a red Corvette in the staging lanes for about ten minutes. It had a badge on the right front fender that said "402". And it had a cammy idle.
That's ALLL I know about it for sure. ALL.
Old Dec 6, 2006 | 04:54 PM
  #78
Hoooper
haha, i wasnt trying to argue with you, i just wanted to know what it was.
Old Dec 6, 2006 | 07:59 PM
  #79
Nealoc187's Avatar
SLOW
Regardless of if it was a Z06 or not, modified or not, 13.1 @ 104 for ANY C6 vette is friggin' LAAAAAME. Hopefully the guy just put a 402 badge on it because if it was a real 402 powered vette that guy should just give up racing, forever.
Old Dec 7, 2006 | 07:21 AM
  #80
grey99max's Avatar
Remember, I just repeated what the tower said about two corvettes that the tower claimed were ZO6s. I didn't see them run. Since there were about 300 cars in eight lanes that day, I have no idea about the performance of the red "402" I sat next to in staging. I'm sure there were more than two 'vettes out that day.
The "402" probably ran low 11's / 120+ mph. They're fast - and I'm sure that going to one of the many Corvette forums will clear this up.
