1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
New PB for the 4.5
Old Jul 15, 2007 | 04:45 PM
Jime's Avatar
New PB for the 4.5
I didn't win any money yesterday but I did manage to beat my old 12.489 @ 109.34 with a 12.480 @ 111.09. Not by much, almost a 1/100. I think there is a little more there I only got 3 runs in before it started raining and that was my last run. I was just bumping up the timing a bit at a time as well as the shift points. Currently using the 350Z intake manifold and with the variable cam timing it looks like its a clear winner over my old setup.
Old Jul 15, 2007 | 05:15 PM
streetzlegend's Avatar
Congrats, your trap speed looks great.
Old Jul 15, 2007 | 06:06 PM
grey99max's Avatar
LandShark has Cosworth
Outstanding! Way to keep the automatic "out front" !
What RPM were you shifting at ??? Man, that's just outstanding.........
Old Jul 15, 2007 | 06:29 PM
Jime's Avatar
Shifting around 6800 but after looking at the logs I can see that it shifts at a different RPM from 1-2 than the 2-3 because of how quick the RPM is building as well as the different speed the trans shifts. I am thinking now of using 2 different MAPS on the EU or using the EU for one shift and the MSD for the other. Because of the longer time it takes for the 2-3 shift the RPM is 2-300 RPM higher so in order to get them both to shift at the same RPM its going to take 2 settings. I was just mulling this over on the trip back so haven't really figured out which way to go yet.
Old Jul 15, 2007 | 06:50 PM
t6378tp's Avatar
Turbo 3.5
nice work, I dying for the day when you spray the car
Old Jul 15, 2007 | 06:56 PM
Tatanko's Avatar
Bacon Lover
New fastest Maxima record
Old Jul 15, 2007 | 07:28 PM
t6378tp's Avatar
Turbo 3.5
you my friend are a mind reader
Old Jul 15, 2007 | 07:37 PM
NmexMAX's Avatar
dot dot dot ...
Nicer times as always. Also,I know you've posted this before, but what Z33 collector are you using? Rev-up?
What does your CVTC curve look like?
Old Jul 15, 2007 | 07:45 PM
Nealoc187's Avatar
SLOW
Outstanding as usual
Old Jul 15, 2007 | 08:05 PM
JClaw's Avatar
Awesome, to think you can run that shifting at only 6800, when that motor could take another 500 RPMs.
Old Jul 15, 2007 | 09:24 PM
maxspeedse02's Avatar
Thinks he is fast
Very nice runs, hard to believe no spray is involved especially considering your track record
Do you have spacers installed on this IM setup? Also I did notice you mentioned MAPs so would this mean you are running w/o a MAF?
Sorry if this is newbish Q's I am somewhat of a newb in this part of the org, not familiar with your setup. What is your exhaust setup with this and suspension?
Old Jul 15, 2007 | 09:46 PM
DandyMax's Avatar
3.5 in the works
Good stuff Jim. What was the 60 ft?
Grey: you just wait until this stick-shift gets a 3.5 and then we'll see how things shake out...
Old Jul 15, 2007 | 09:53 PM
JClaw's Avatar
1 more vote for the stick! But his car is alot lighter than yours.
Old Jul 16, 2007 | 05:04 AM
Jime's Avatar
Using the MREV2 Manifold with a 5/16 spacer from Motordyne. I still don't have the V-Manage working so not sure what the CVTC curve looks like.
Here is the slip, the second one is against a Hemi Cuda with open headers etc, he was ahead all the way and I passed him less than 100 ft from the end. Not the fastest run but the most satisfying one. Especially since it was MOPAR day at the track.
I'm not using the 2-step because one of the classes I race in won't allow it and with an auto it has a delay before it kicks in so not really useful. However with the drive-by-wire setup the gas pedal sends a variable resistance to the ECU which then sends a signal to the throttle motor and opens it. So I have placed a resistor through a relay that only allows 30% throttle when the pedal is to the metal and as soon as I release the line-loc it goes to 100%. Works great. Even with my new dual piston brakes the car easily overpowers them so I have to have some method of line control for consistent r/t's.
Old Jul 16, 2007 | 06:19 AM
DandyMax's Avatar
3.5 in the works
Can't see the slip Jim...
Old Jul 16, 2007 | 06:45 AM
Jime's Avatar
Try again Dan, my server is causing me headaches.
Old Jul 16, 2007 | 07:00 AM
ajcool2's Avatar
Nice runs Jime. Do you have any other plans on going faster N/A? Future mods?
Old Jul 16, 2007 | 07:08 AM
DandyMax's Avatar
3.5 in the works
Nope still no workee Jim..
Old Jul 16, 2007 | 08:08 AM
grey99max's Avatar
Dandy, this ol' man has a nice 3.5 for his automatic, so we shall see.....
I broke my 3.0 -again -, so 3.5 gaskets and cam adapters are on order. Of course, I still run with the entire car and spare tire, and it's 3300 lbs on the line, so who knows...... Heck, I'm probably going to have to use an EU this time.
Old Jul 16, 2007 | 08:54 AM
Nealoc187's Avatar
SLOW
The picture of the slip is not showing for me either. Jime the electronic wizardry you have going on with your car always astounds me. If something's not working how you want it, you just add a relay and a circuit and change how it works lol
Grey how do you keep breaking your motors?
Old Jul 16, 2007 | 09:24 AM
DandyMax's Avatar
3.5 in the works
lol ain't that the truth.. Jim is the relay man for sure!
No kidding, what are you up to now Grey, #4?
Old Jul 16, 2007 | 12:09 PM
grey99max's Avatar
Yes, this is #3...
Breaking them is easy - spray lots of nitrous, sprinkle liberally with 'stupid' - and Voila! it goes BOOM !
I melted valves out of the first two while learning how to spray a dual-shot of 150 combined. I chose to replace them with junkyard-dog motors instead of swapping heads. I wasn't sure I can do that. This last one took me all the way through last November with no problems - and the final 13.158 ET - when it was parked until I took it out July 11th. On the first pass, I launched fine, got into second and hit the second stage and ate a piston - well, put a hole in it. Made some neat smoke and bangs at the same time. Kinda like some of the PINKS episodes...
The #4 cylinder has a very oil-wet plug, and the rest are suddenly bone-white. The engine went very lean when I sprayed second-stage. I don't know why - yet. Fresh 103-octane race gas in the tank, old reliable M&Hs at 20 psi, and it launched very hard on the 75-shot.
The car has been sitting since then - family drama continues (had a new grandson today) but I had the car out on the on-ramps w/DRs mounted and sprayed it hard with no problems - except staying on the road. The headers helped with that.
I'm sure I have enough parts to build another 3.0, but the 3.5 looks like it's next in line...
Old Jul 16, 2007 | 12:21 PM
Tatanko's Avatar
Bacon Lover
Make sure you prep it well enough this time
Old Jul 16, 2007 | 12:52 PM
grey99max's Avatar
Prep it? Prep what? New spark plugs and oil change is all they ever get...
Old Jul 16, 2007 | 01:11 PM
95BLKMAX's Avatar
Dont forget seafoam. It will smoke out all the bad spirits from the motor and give you 10WHP throughout the powerband
Jim!....
Old Jul 16, 2007 | 01:22 PM
grey99max's Avatar
Jim!....
Yeah! for Jime.......
Seafoam, eh? Maybe that's why the last motor was puffing crankcase smoke........ not that darn nitrous stuff after all........
I've had some monumental foul-ups on the track, but no pictures or videos of any of them.
Old Jul 18, 2007 | 11:57 AM
Jime's Avatar
Would someone let me know if my slips are showing now on Post #14.
Tnx
Old Jul 18, 2007 | 12:00 PM
gtr_rider's Avatar
192.168.1.1
working fine for me
Old Jul 18, 2007 | 12:10 PM
Jime's Avatar
Originally Posted by gtr_rider
working fine for me
Tnx, think I finally got the server back up and running. Its almost as much work as a 3.5 swap.
Old Jul 18, 2007 | 01:51 PM
Ceasars Chariot's Avatar
Old Maxima Legend
nice work, that maxima of yours is a beast. hope you get the money next time ! rain has robbed me of some loose change too.
Old Jul 18, 2007 | 02:56 PM
STILLENGLE's Avatar
Nice runs man now get a spray bottle then you would have a much faster max maybe in the 10 second range. now that would be sweet.
Old Jul 18, 2007 | 03:07 PM
Jime's Avatar
I have 3 spray bottles, just sitting here waiting for the occasion. However I am not quite finished with N/A yet.
Old Jul 19, 2007 | 11:55 AM
JClaw's Avatar
I think 10s are too optimistic. Its very hard to drop 1.5 seconds when you're already doing 12s, especially since he will have to retard timing for spray. I think this car will go mid 11's@118-120 on a 100 shot. 10's would probably take a 150-175 shot and a whole bunch of traction.
Old Jul 23, 2007 | 06:27 PM
krismax's Avatar
Father of the 00 VI
it hurts me to see these wonderful times and not being able to counter
Times are outstanding ,i miss racing . but iam out for the 07 season my car wont see the track at all . maybe not till late 08 season with a EU . need to get some stuff done in my life first.
by then i may have a long catching up to do
Old Jul 24, 2007 | 06:24 PM
DandyMax's Avatar
3.5 in the works
Yes indeed you will...
Look I don't mean to be a jerk, but for how light your car is, being manual and a 3.5, it's never come close to tapping the full potential...
I can understand that other things in life take priority at times though.
Old Jul 25, 2007 | 05:11 AM
JClaw's Avatar
Yeah otherwise I'd be collecting timeslips right now.
I think it was Neal that said that modding never really stops, just temporary set off while you have no money.
And I gotta agree with that. If I had 20,000$ of disposable income right now I know DAMN well where most of it would go
Old Jul 30, 2007 | 01:06 PM
95turbo gxe's Avatar
Great run Jime. thats anice trap to over your old trap. Did just the 3.5 ecu swap do all this or is their other things involved?
Old Aug 15, 2007 | 06:59 PM
MardiGrasMax's Avatar
Hi Jim, nice times, juice it already!!!
I now have a G35 5AT and was wanting to know more about the resistor mod on the throttle pedal you use with your line lock.
You have the resistor in parallel with the actual TPS signal wire so when its not activated the signal follows the path of least resistance through the OE wire and when its activated the relay interrupts the OE TPS signal wire so the signal has to go through the resistor? This way the relay would not actually ever cut the circuit and cause a CEL?
The resistor reduces voltage by a linear amount? So at 50% actual throttle position the ECU only sees 15% and at 100% throttle position the ECU sees 30%. What size resistor was required to get you to 30%?
Are you using a standard mechanical relay or something faster?
I assume that by using the line lock you dont have the issue where when the throttle pedal and brake pedal are pressed at the same time the ECU limits the throttle body opening and causes a loss of power on launch?
Does this launch you like a pseudo trans brake set up?
Does the 30% throttle position hold you right under the stall speed?
Thanks,
Matt
Old Aug 16, 2007 | 08:05 AM
hacim105's Avatar
Thanks,
Matt
I don't know if you already know this, but he was hospitalized after a fall, so it might be a little while before you hear anything from him, if you hear anything at all.
Old Aug 16, 2007 | 08:55 AM
dam, hope Jim is okay?
