1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
DR Mod help.....
Old Oct 26, 2007 | 08:32 PM
i30dvr's Avatar
DR Mod help.....
Can someone help me find Jime's post for the DR mod. It will not let me search and I tried googling it but didn't have any luck with the actual write up.....
Old Oct 26, 2007 | 11:12 PM
t6378tp's Avatar
Turbo 3.5
try the nitrous forum
Old Oct 27, 2007 | 12:35 AM
streetzlegend's Avatar
Simple, you locate the drop resistor (on the driver side strut tower), then pick any of the two wires and cut it, then one leg goes into a WOT(wide open throttle switch), then from WOT switch wire goes into the other leg. So when you floor it, it disconnects the drop resistor. the WOT switch needs to be Normally Closed, meaning it should be providing a connection between the two wires, so when you floor it, it disconnects them
Old Oct 27, 2007 | 02:44 AM
ajcool2's Avatar
^^What he said.
Or instead of doing a WOT switch you could put a switch in the cabin and turn it on and off when you want like mine. Glad to see your finally going to try it. Have fun and heres the link.
http://forums.maxima.org/showthread.php?t=208756
lrb6805
Sep 30, 2015 08:12 AM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
