1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
PB: 13.9 5spd 95 3.0 N/A
Old Mar 24, 2008 | 03:56 PM
ghostmax301's Avatar
decided to go to the track today and see how the car ran, my PB of the day was a:
60 -2.12
1/8 -9.045
MPH -78.14
1000-11.727
1/4 -13.987
MPH -98.25
(my best 60ft was a 2.066/best trap mph was a 99.75)
My mods, cars condition for the track
ksport springs with kyb gr2 in the front(stock rear shocks)
00vi swap
5spd
5th gen clutch kit
untuned V-AFCII
Warpspeed Ypipe
fully gutted stock cat
custom bpipe with Apexi WS2
about a 8" long mid pipe from the TB to the MAF
FSTB
JWT ECU tuned for auto USIM
the bad about my car,
-I had 1-205/50/16 & 1- 215/55/15 up front.(1 240sx wheel/ 1 sawblade)
-2x 235/55/16 rx7 wheels in the rear(dont ask why i had it set like this)
-both front tires just about bald
-full interior
-COMPLETELY blown rear struts with fluid leaking out(car bounced up and down the ENTIRE track)
-Busted flex pipe, pretty much running 1/2&1/2 the whole time(going out the tip and the flex)
oil hasnt been change in about 7k miles
running about a 10.8 AFR from 3.2k-5.7k
What do you all think? good or bad time?
Old Mar 24, 2008 | 04:35 PM
ajcool2's Avatar
Your times suck. Learn how to drive.
Naw I'm messing with you. Good runs. One of these days I'll fix my car.
Old Mar 24, 2008 | 04:52 PM
streetzlegend's Avatar
that seems pretty quick. how much does ur car weigh?
Old Mar 24, 2008 | 05:07 PM
DandyMax's Avatar
3.5 in the works
Excellent 60' for street tires!
Old Mar 24, 2008 | 05:10 PM
well, with all 240sx wheels and no pass. & backseat/empty trunk with me in the car. it came in at 3083 with about a 1/4 tank. I'd say with full interior and same gas(i had 1/2 tank at the track) It would probably be about ~3140
Old Mar 24, 2008 | 05:16 PM
thanks, Im on my 3rd MT and this one was rebuilt(unlike the last two) so im kind of afraid of dumping the clutch or revving to ~2k and dropping it. I know cant too much harm happen but I also am afraid of the tires breaking loose. My technique is simply just feathering/patting the gas(never goes above 1.6k) so once the last yellow goes, i kind of slip the clutch & gas at about ~50% until about 20mph then fully lift off the pedal and drive
Old Mar 24, 2008 | 05:35 PM
Nealoc187's Avatar
SLOW
lol @ two different sized tires in front.
excellent time.
Old Mar 24, 2008 | 05:39 PM
excellent time.
yea. 1 tire blew out, thats where the 1 sawblade came in at.
the rear was because vqmonster put the wrong tire on the rx7 wheels and it made them EXTRA heavy, lol. so he wanted to use 2 of my wheels and i didnt want to give him 2 different wheels soo....lol. next time will probably have 240sx wheels or millenia wheels up front with DRs and millenia's in the rear with like a 195/205 on it.lol LESS DRAG
Old Mar 24, 2008 | 05:43 PM
Puppetmaster's Avatar
Seriously, excellent time for a VQ30.
Old Mar 24, 2008 | 06:32 PM
ajcool2's Avatar
Now RMT it.
Old Mar 24, 2008 | 07:17 PM
lol, still have the UDP, AFR tune, lightweight flywheel and pathfinder throttlebody to try out. then its either paint/lip kit/wheels or RMT
Old Mar 25, 2008 | 06:30 AM
t6378tp's Avatar
Turbo 3.5
00vi swap
5spd
5th gen clutch kit
untuned V-AFCII
Warpspeed Ypipe
FSTB
-full interior
I sorry this smell alittle like BS. not trying to be a jerk but you ran the car with all kinds of problems, full interior and with a jwt ecu that tuned for a 10.8 a/f and then brag about not changing your oil and running two different size tires. but if for some reason this is true GREAT times, fix your problems get tuned and some dr's and maybe you'll run 10's
Old Mar 25, 2008 | 08:55 AM
1sexyleo
60 -2.12
1/8 -9.045
MPH -78.14
1000-11.727
1/4 -13.987
MPH -98.25
00vi swap
5spd
5th gen clutch kit
untuned V-AFCII
Warpspeed Ypipe
FSTB
-full interior
ur a fukking liar......u changed ur oil the same day i did which was the day b4 u ran at the track
i smell BS....u and ur damn BROTHER...full of lies. stop claiming problems on ur car.
but he did run a 13.98......
Old Mar 25, 2008 | 09:35 AM
AJ's Silver CL's Avatar
Those are really good times !!!!
Old Mar 25, 2008 | 09:40 AM
cardana24's Avatar
Blown
you and I basically have the same mods and are running similar times...good runs. Have you dynoed the car yet? I know with my JWT and VAFC-II I actually had to add a little bit of fuel to get back to 13:1
Old Mar 25, 2008 | 11:36 AM
nooooo, i wasnt changing my oil. I was changing my friends oil.. check my filter,i twas orange. its now black.lol
Old Mar 25, 2008 | 11:41 AM
1sexyleo
ur brother said u was changing ur oil....lol.
Old Mar 25, 2008 | 12:31 PM
Jay_pee99's Avatar
He was changing some elses
Old Mar 25, 2008 | 12:49 PM
1sexyleo
u told me he was changing his....lol
well its done now....
Old Mar 25, 2008 | 12:55 PM
t6378tp- just for you i will post video proving my exhaust leak/blown shocks/ and tire combo and also a scan of my dynosheet with afr on it. also the ecu is not tuned for a 10.8..thats how rich my car is running due to 5th gen injectors. i think the vafc also has a preset of +3 fuel correction
Old Mar 25, 2008 | 02:58 PM
t6378tp's Avatar
Turbo 3.5
don't bother, you do not have to prove anything to me this was just my opinion. like I said if you did run these time then great job
Old Mar 26, 2008 | 05:45 PM
NmexMAX's Avatar
dot dot dot ...
Strange that the AFR is that way when he's got a JWT.
Old Mar 26, 2008 | 08:33 PM
well, it was that way with the stock ECU. It was at a 10.4afr. Now i have the JWT(tuned for the 260cc injectors{or whatever the size is on the USIM})and a newly discovered bad Bank1 o2 sensor so im almost 100% sure its around there. the car gargles, backfires and pops during daily driving. In between shifts, decelerating, etc.... also theres a decent amount of black smoke from the tailpipe when im WOT
Old Mar 26, 2008 | 08:35 PM
cardana24's Avatar
Blown
aaron, can you post your dyno. I would like to see it since we have the same mods but when I dynoed with out an a/f correction i was a little over 13:1, and I too have 5th gen injectors.
Old Mar 26, 2008 | 08:52 PM
NmexMAX's Avatar
dot dot dot ...
I’d say you’re leaner than that. The O2 sensor has no input during WOT (1/4 mile) operation.
Old Mar 26, 2008 | 10:51 PM
The Russian's Avatar
wow, shocked with your times, but great job.
Old Mar 27, 2008 | 06:27 AM
BTW, this was with stockECU. and i "believe" the o2 sensor was good for these pulls. Also, 2 of the guys from AAM told me my car might be a little richer then what the print out showed because of the AFR reader being at the muffler tip, and my exhaust leak being before the cat.
This run was also done without the intake midpipe and with the power rod in the mainfold removed(which i will never do again)
Old Mar 27, 2008 | 06:46 AM
t6378tp's Avatar
Turbo 3.5
I am starting to smell bs again. make up your mind were you using the jwt ecu or not
Old Mar 27, 2008 | 06:51 AM
NmexMAX's Avatar
dot dot dot ...
Dyno runs aside, which ECU did you run the 1/4 mile time with?
Old Mar 27, 2008 | 04:42 PM
I ran ONLY at the track with the ECU like i said. Those dyno runs were almost a month 1/2 ago with stock ECU(as i stated). I only had the JWT ECU in for that track day.
JWT ECU, 7200 rev limit. tuned for USIM
Old Mar 27, 2008 | 05:47 PM
just thought I'd throw this in
Old Mar 27, 2008 | 06:00 PM
annnnnd the number on my car
Old Mar 27, 2008 | 08:09 PM
NmexMAX's Avatar
dot dot dot ...
One thing is for sure, your ca was not running as rich as you thought if that run was with that ECU.
Old Mar 28, 2008 | 09:57 AM
not sure what your talking about but that dyo pull was with the stock ecu just for reassurance
Old Mar 28, 2008 | 12:45 PM
NmexMAX's Avatar
dot dot dot ...
I was referring to this:
It's not substantiated, because I have never seen the JWT ECU let anyone run that rich.
Old Mar 28, 2008 | 10:29 PM
IC..
Just IMO because of the black smoke/ backfire/popping
Old Apr 3, 2008 | 03:10 PM
punjabi's Avatar
man i give you props for 2.1 60' on st tires
Old Apr 4, 2008 | 09:40 PM
VQrebuild96's Avatar
60 -2.12
1/8 -9.045
MPH -78.14
1000-11.727
1/4 -13.987
MPH -98.25
00vi swap
5spd
5th gen clutch kit
untuned V-AFCII
Warpspeed Ypipe
FSTB
-full interior
Nice times nice 60' ... get a high flow cat or test pipe... Fix your car man don't let problems pile up. peeece
Old Apr 4, 2008 | 11:21 PM
replacing parts day by day. new PB coming soon.. fixing leaking oilpressure switch tomorrow. alignment and o2 sensor and changing oil.. going to try and get a 13.8 before my bday(april 12th)
Old Apr 7, 2008 | 08:00 PM
NmexMAX's Avatar
dot dot dot ...
Check the weather forecast and shoot for lowest humidity and lowest temperature (oxymoronic, sorta) . . .
