1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Went to the track for the 2nd
Old Mar 13, 2009 | 06:47 PM
93altima's Avatar
Turbo 4th Gen
well i went to the track for my 2nd time ever but this time as a 3.5. I put up a new PB but i only got 2 runs in before they kicked me off because i had a gear oil leak(stupid pass. side axle seal) but heres my #, pics, and vids
1st run: the 60' sensor wasnt working in the left lane so idk the 60'
R/T: .177
1/8: 9.2
MPH: 78
1000: 11.8
1/4: 14.1
MPH: 100
2nd run: i launched way to high and spun the Dr's through all 1st
R/T: .318
330: 6.2
1/8: 9.4
MPH: 77
1000:12.1
1/4: 14.4
MPH: 98
Mods:
3.5 Swap
Custom Cold air intake
Warpspeed Y
Test Pipe
Cat-Back
Short Throw Shifter
Stock Clutch
Mickey Thomson 15in Drag Radials
Old Mar 13, 2009 | 07:01 PM
accordingtou's Avatar
VQ30 DE T
Old Mar 13, 2009 | 07:24 PM
Grand_hustle17's Avatar
5spd or auto???
Old Mar 13, 2009 | 07:32 PM
93altima's Avatar
Turbo 4th Gen
my 1st Run:
My 2nd Run:
My 3rd run where i got kicked off:
Old Mar 13, 2009 | 07:33 PM
93altima's Avatar
Turbo 4th Gen
5spd or auto???
5spd
Old Mar 13, 2009 | 07:41 PM
secondtonone317's Avatar
nycnissans
nice.......
Old Mar 13, 2009 | 09:37 PM
MaximaSpd85's Avatar
nice run, whats up with the exhaust? or is it just the video? kinda loud, like you unbolted the exhaust somewhere.
also, the car is fast and all, but i think its time for some spring cleaning, lol. (front lip falling off, fog light, engine bay, etc.)
Old Mar 13, 2009 | 11:36 PM
wyche89's Avatar
i see 13s in your future...
Old Mar 14, 2009 | 03:57 AM
t6378tp's Avatar
Turbo 3.5
Jean the burnout's were not long enough for the temp's, did you pull the e-brake
also ingore those dumbazzez at the track when it comes to the waterbox they were bring you up too far and had your rear tires in the water. put the front tires in the water and just flag them off
start the burnout there with the e-brake on till the dr's start to pull you out
all in all nice times for your 1st time out
Old Mar 14, 2009 | 07:32 AM
93altima's Avatar
Turbo 4th Gen
My exhaust is str8 through, thats how it sounds daily.
Yea one step at a time its more Go than Show at the moment
Old Mar 14, 2009 | 07:35 AM
93altima's Avatar
Turbo 4th Gen
Hopefully
Old Mar 14, 2009 | 07:37 AM
93altima's Avatar
Turbo 4th Gen
Thanks for the advise, i pulled the ebrake in the 2nd, 3rd run
and thanks
Old Mar 14, 2009 | 07:41 AM
VQ30 DE T
Go before show.
Order one of these so you can squeeze a lil more power out your setup.
http://cgi.ebay.com/ebaymotors/ws/eB...80987&viewitem=
Old Mar 14, 2009 | 10:09 AM
geoffc's Avatar
Are those 26" tires? That's probably a little too much tire. I noticed you're nowhere near 4th when you cross the traps. I think you would be see a decent improvement in ET if you tried some smaller diameter tires like 225/50-15 MTs.
Also, are you doing your burnout in 1st gear. If so, try 2nd. It's a little harder on your drivetrain, but it'll heat up the tires better. I prefer to spin the tires just a little while I roll through the waterbox. Then I start my burnout at the end of the waterbox.
Looking into my crystal ball, I see mid-low 13's in your near future.
Old Mar 14, 2009 | 06:32 PM
JAMAICANLOVRBOY's Avatar
nice runs man, what did you break, what was leaking?.
Old Mar 14, 2009 | 07:11 PM
93altima's Avatar
Turbo 4th Gen
idk the specs on the Dr's they were rented for the day but ill see if i could squeeze mid 13's on the motor then comes the spray and or Boost
but thanks for the info
Old Mar 14, 2009 | 07:12 PM
93altima's Avatar
Turbo 4th Gen
Originally Posted by accordingtou
Go before show.
I See Some Tuning in my future lol
Old Mar 14, 2009 | 07:14 PM
93altima's Avatar
Turbo 4th Gen
i didnt break any thing thank god but iam leaking gear oil at the moment which i already knew
Old Mar 14, 2009 | 07:22 PM
VQrebuild96's Avatar
My axle seal leaks too. I changed it two times with the correct one....and it still leaks....it is so annoying.
How are you running the stock clutch? My 3.0 makes the stock clutch smell when i launch it.... I could only imagine what that 3.5 is doing to the stock clutch.
Old Mar 14, 2009 | 09:30 PM
93altima's Avatar
Turbo 4th Gen
you might be burning your clutch my clutch is holding for now
Old Mar 14, 2009 | 10:15 PM
I don't know man...its kind of hard to believe the stock clutch would hold up to that kind of torture.
Old Mar 15, 2009 | 01:11 AM
93altima's Avatar
Turbo 4th Gen
please dont jinx me after i hit 13's the clutch could slip all it wants idc but until then i need it to stay together until after maxus
Old Mar 15, 2009 | 05:05 AM
t6378tp's Avatar
Turbo 3.5
they are 26inches but I am going to get a set of 24.5inches slicks soon
Old Mar 15, 2009 | 07:28 AM
LONERANGERSR20's Avatar
nice runs man,when u go bacc u betta run 12s,lmao
Old Mar 15, 2009 | 07:47 AM
93altima's Avatar
Turbo 4th Gen
i prob wont see 12's until mid-summer but only time will tell
Old Mar 15, 2009 | 11:09 AM
New People................
Old Mar 15, 2009 | 10:13 PM
well i learned this the hard way, but when you fill the transmission up with gear oil, you gotta let it drain before you close the fill plug. too much gear oil in the tranny can mess up the seal. perhaps thats what you are doing
Old Mar 16, 2009 | 08:18 AM
Wait.... so your saying when you fill it up... let it drain? Should I be topping off the gear oil? I don't really understand what you mean by let it drain. Let how much drain? Or just not fill it up to that amount that causes it to break the seal?
Old Mar 16, 2009 | 06:06 PM
maxboy325's Avatar
What RPM are you trapping at???
Old Mar 16, 2009 | 06:30 PM
t6378tp's Avatar
Turbo 3.5
read post # 1
Old Mar 16, 2009 | 08:03 PM
93altima's Avatar
Turbo 4th Gen
I trapped 100mph and that's redlining 3rd gear you'll hear it in the 1st vid
Old Mar 16, 2009 | 10:14 PM
maxboy325's Avatar
read post # 1
Please show me where thats listed in the first post. I think you misread my question it was what RPM not what was you trap
Old Mar 16, 2009 | 10:15 PM
maxboy325's Avatar
OK thats what I thought. Good run no 4th gear shift
Old Mar 17, 2009 | 06:01 AM
321VQ35MAX's Avatar
If you are trapping 100 mph, there is a 13 second pass in the very near future. I would be happy with a 13.999 @ 100 mph. LOL! Good runs!
Old Mar 17, 2009 | 04:22 PM
93altima's Avatar
Turbo 4th Gen
iam about to install my headers, clutch and tune it so hopefully sometime in april ill get my 13 sec. slip then its on to stage 2 of my setup
Old Mar 17, 2009 | 04:44 PM
hmmmmm whats stage 2, do tell....man yall throwing in engines, clutches, etc like yall changing brake pads. what da heck. man if you look under your hood in my neighborhood, people look at you funny, they dont want a spec of oil on the asphalt...this has been on my mind for a minute now. why is it that when you swap the VQ35 in a 4th gen, it doesnt have that 350Z/G35 like growl like when its in the 5.5 gen, is it cuz most people use the 3.0 ECU, which doesnt allow the use of VTC/timing, etc. to me it sounds like the 3.0, just with a lot of bolt-ons. i heard one on the dyno, and if you didnt look under the hood, you would not be able to tell he had a 3.5 in his 4th gen....just curious
Old Mar 17, 2009 | 06:56 PM
93altima's Avatar
Turbo 4th Gen
yea mines dosent sound like a z but it does sound slightly different than my de or de-k
Old Mar 18, 2009 | 06:22 AM
321VQ35MAX's Avatar
With all those additions you will easily be in the 13 second class. Good luck. Keep us posted.
Old Mar 19, 2009 | 06:58 PM
maxboy325's Avatar
Too many things to take in account exhaust and intake manifolds ecu's simply put a Maxima will never sound the same as a Z. A Maxima can sound awsome but there are alot of differences in the the setups
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
mkaresh
Mar 12, 2018 06:48 PM
jonreidhead
Jan 6, 2016 09:38 AM
