Control Arm Bushings...
Old Aug 6, 2002 | 06:26 AM
MaxWgn's Avatar
Anyone here replace their control arm bushings? How difficult are they to replace? I looked in my Haynes manual, and it basically says, if they're worn, replace the entire control arm as an assembly. There's got to be a way to change just the bushings. Do I need to take them to a shop to have them pressed in, or what?
Any advice is welcome.
Old Aug 6, 2002 | 02:09 PM
maxima561's Avatar
i did the one on the passenger side and I had to use a press to get the old one out and put the new bushing in. It is not too hard to do but it will require taking the a arm to a shop and having them do the press for you.
Old Aug 7, 2002 | 10:18 AM
MaxWgn's Avatar
OK, I'll need to call around, and get a quote on that...I will likely be replacing my front wheel bearings soon, also...
Thanks for the info...
Old Aug 7, 2002 | 11:25 AM
max95q's Avatar
Front wheel bearings shuldnt be hard at all. If youve done brake work on your car then you can change the wheel bearings.
tarun900
19
Dec 20, 2021 06:57 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
