flasher location 1985
Old Jan 31, 2003 | 09:34 AM
markNYNY's Avatar
The turn signals and 4 way flashers recently quit working on my 85. I suspect the flasher and have been trying to replace it, but for the life of me I can't locate it! Usually it is under the dash on the drivers side. Any help that can be provided would be appreciated.
Thanks,
MarkNYNY
Old Jan 31, 2003 | 10:36 AM
MarkC's Avatar
Re: flasher location 1985
You should be able to find it located near the steering column under the center kick panel. Also, if you haven't already checked, make sure the fuse isn't blown.
Old Jan 31, 2003 | 12:22 PM
markNYNY's Avatar
Re: Re: flasher location 1985
Thanks for the info. Found the flasher, replaced but no joy. I checked the fuses for hazards and turn signals in the fuse block and they were OK. Lokking at the Wiring diagram for the car it appears their is a dedicated fuse for the flasher unit. Any idea where this may be located?
MarkNYNY
Old Jan 31, 2003 | 02:27 PM
maximase86's Avatar
I love lamp.
Re: Re: Re: flasher location 1985
MarkNYNY
Check in the engine compartment next to the intake air duct. There are some fusible links there that could of gone bad...though I'm not 100% sure. Also check along the spine of the positive battery cable as it has a bunce of other wires running from it.
S
my03maxima
Jul 28, 2024 07:40 AM
aw11power
Oct 10, 2021 04:57 AM
RealityCheck
Oct 2, 2015 06:34 PM
fx4five
Oct 1, 2015 04:58 AM
