85 Maxima fails smog-high Nox
Old Jan 9, 2001 | 11:08 AM
steve60
Just attempted to smog my 85 Nissan Maxima wagon and although the car seems to be running very well it failed the California Smog II. It had high Nox readings. The technician kind of pointed me to the O2 sensor (I replaced it) and the EGR (I checked vacuum signal from solenoid to valve and checked the valve for obstructions and operation by applying vacuum to it). Looking for other inputs as to what might cause this failure.
Old Jan 12, 2001 | 09:31 PM
shelmoney's Avatar
me 2
dont worry mines will most likely 2 that too lol
p.s get illegal somebody might do it for ya
Old Jan 19, 2001 | 07:39 PM
got rice?'s Avatar
most likely it's the catalytic converter.
Old Jan 19, 2001 | 10:53 PM
Bearcats's Avatar
test...sorry
Old Jan 19, 2001 | 10:55 PM
Bearcats's Avatar
test again
Old Jan 24, 2001 | 02:04 AM
There is another thing that also causes NOx readings to go high. If your cat converter is not doing the job, it will cause it to fail. If you have not had it replaced, it may be disintegrated inside already. Sometimes you could hear the stuff rattling inside.
LilVito
Oct 25, 2019 08:12 AM
PH98I30
19
Jun 13, 2016 02:38 PM
laparka66
Aug 6, 2015 09:36 AM
yat70458
Aug 3, 2015 01:16 PM
