2 part question.
Old Mar 17, 2003 | 04:40 PM
IROC Z's Avatar
2 part question.
Does a 84 maxima have OBD? If so how would I go about pulling any codes the ecm may have stored?
My 84 is running pretty well but I would like to run any possible codes since it does stutter a little when cold and has a wierd surge when using the accel on the CC.
Old Mar 17, 2003 | 05:14 PM
maximase86's Avatar
I love lamp.
Re: 2 part question.
No, it doesn't. I don't think OBD appeared on maxima's until mid-3rd generation. The ecu codes are probably pulled the same way as the 2nd gens, but I'm not 100% sure. You might wanna check a FSM for your car to see if it has the procedure in it.
S
Old Mar 18, 2003 | 10:40 AM
Bleach's Avatar
I don't know for sure, but I've never heard of any 280ZX or 1st Gen Maxima with "codes" to pull. Its a basic analog style computer controlling 2 banks of fuel injectors back and forth with injection open times. That's all.
Your air regulator, and other sensors are what usually go bad.
Old Mar 18, 2003 | 04:10 PM
IROC Z's Avatar
that would make sense since the engine will run even if its consuming a ton of gas and a simple O2 makes such a huge difference in this model.
I'm a little less impressed with the maze of tubing, hot coolant and vacuum. What a pill this will be when I really do have a problem.
derekinthez
Nov 13, 2022 04:00 PM
Mar 12, 2020 12:06 AM
SpeedCrazie
Sep 16, 2016 03:41 PM
Lowered_a33
Sep 10, 2015 09:41 PM
videomano
Sep 8, 2015 03:28 PM
