HELP PLEASE with manual transmission problems :(
Old Mar 24, 2004 | 08:58 PM
hgallegos915's Avatar
Does anyone know IF the source of my problems could be that small metal piece that holds the support shift rod? If its missing and just the support rod is connected to the transmission will it cause my transmission to grind second gear and sometimes 1st? Also can a bad positioned shift rod cause your gear to pop? it sometimes does it. I go into first and it pops into neutral. CAn this be bad syncros? Im really hoping its that metal piece that I dont have there. The haynes manual has it pictured..loks like a small plate with a screw popping out of the base (its where the support rod is supposed to be connected) Sarin has told me its possibly a bad tranny..anyone else got ideas?? anyone alive? Im so stressed here...
-Hector
Old Mar 27, 2004 | 06:51 PM
John L's Avatar
Umm
-Hector
My MG does what you are describing, I'm pretty sure the clutch slave cyl. needs to be bled. ...or the synchros are going???
Old Mar 28, 2004 | 04:33 PM
I rebuilt the slave .. compared it to another max (85) and the rodas are correct.. Its defenetly a bad syncro. Im going to probably swap it for a 4th gegn or see if i can get it fixed.
Old Mar 28, 2004 | 06:03 PM
maximase86's Avatar
I love lamp.
Bad syncros suck.
S
Old Mar 29, 2004 | 05:40 PM
what do you know Its getting fixed for free
Old Mar 29, 2004 | 07:10 PM
maximase86's Avatar
I love lamp.
Huh? How the h3ll?
S
Old Mar 30, 2004 | 04:31 PM
Oh, the yard decided send it in to their shop (sum transmission place) and have it either rebuilt or replaced. Im like...well free is good Oh I found a place that sells remanufactured maxima transmissions for 120 dlls with 6 months warranty. not bad but like i said...free is better than paying.. now what to do with the extra 300 dlls i have :/ lighweight flywheel?
MAXSE5SPD
Sep 17, 2022 04:00 AM
sctludwig
Sep 1, 2022 01:32 PM
boomerbrian
Oct 31, 2018 10:25 AM
pjgreek
Sep 9, 2015 09:30 PM
