Vacuum hose diagram
Old May 25, 2004 | 02:51 PM
ebailes's Avatar
Vacuum hose diagram
When putting the air collector back on, I came up with a vacuum hose for which I couldn't find a place. It is a 3/8 hose with a white plastic nipple on it that looks like it should have 1/4 " hose attached. It comes out of the bottom of the air collector and is about 9 inches long, terminating just about at the intake boot. Can anyone tell me where this is supposed to go or connect to? If not, can you direct me to a site with a vacuum diagram? Thanks.
Eddie
Old May 25, 2004 | 04:13 PM
maximase86's Avatar
I love lamp.
Do you mean it's attached the the black elbow that goes to the throttle body, or the gray looking resonator/airbox, or the actual airbox itself? I'll try to remember how everything is routed and get back to you on that.
S
Old May 25, 2004 | 04:46 PM
ebailes's Avatar
vacuum diagram
The hose comes down from under the throttle body and looks like it goes toward the elbow going into the throttle body. ( toward the driver side of the engine ) I have it plugged right now and the car will start fine. However, when I rev, the rpm's go down hardly at all. When I unplug it while running, the engine starts to sputter and cough. Thanks for any help.
Old May 26, 2004 | 04:07 AM
cardana24's Avatar
Blown
there is one that goes in: if you are looking at your front valvle cover it up and to the right a little....you may need a flash light to see it because I had a hard time re-locating it even though I replaced mine one by one
Miket2006
Mar 1, 2021 03:55 AM
conansriver
Nov 18, 2015 02:46 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
MaxDD
Sep 24, 2015 06:40 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
