transmission cooler lines
Old Jun 29, 2004 | 12:25 PM
Niku-Sama's Avatar
just a quick Q.
any one know what size the auto matic transmission cooler lines are for an 87?
i'd like to get a seperate transmission cooler and extend the life if the fluid a little more but i cant find what size the hose is and i am sure if i take them off theyre going to rip or disentigrate like my lower fuel line did.
Old Jun 29, 2004 | 01:07 PM
maximase86's Avatar
I love lamp.
Might check with max88q. He has a hayden 404 tranny cooler. I'm not sure of the line sizes, but they are probably going to be pretty generic.
S
Old Jun 29, 2004 | 02:53 PM
Niku-Sama's Avatar
i'm thinking about something like this
Old Jun 29, 2004 | 04:29 PM
maximase86's Avatar
I love lamp.
Looks like it'll have everything you need to hook it up. I notice it has clamps etc. I say order it test it out, if it doesn't work, you can go grab new hose at the local parts store.
S
Old Jun 29, 2004 | 04:35 PM
Niku-Sama's Avatar
i'm just using that as a pic the one i am looking at is $5 less and doesent have fittings like this one, theyre just clamp the hose to them fittings, its just the core also i'm going to have to buy everything else, not that rubber hosing and hose clamps are expencive i just dont know what size hose it is
Old Jun 29, 2004 | 04:41 PM
maximase86's Avatar
I love lamp.
Well what you could do is take the core with you when you get the hose. You'll have a reference with you.
S
Old Jun 29, 2004 | 04:46 PM
Niku-Sama's Avatar
but i want to know the size of the lines comming out of the transmission it self to get the same size on the transmission cooler so i dont have to run any sort of adaptors....i'm just trying to stay away from leaks
Old Jun 29, 2004 | 05:33 PM
maximase86's Avatar
I love lamp.
that's what clamps are for.
S
Old Jun 29, 2004 | 05:52 PM
ASHURA's Avatar
it should be around 3/8" I.D., which is pretty universal as tranny cooler line goes.. an engine oil cooler... that'd be another matter entirely..
Old Jun 30, 2004 | 08:15 AM
arsonist63086's Avatar
just a sugjestion for ppl who live near a junk yard or now were 1 is.
y do u guys just go to the junk yard and take some tranny coolers and oil cooler frome the cars. when i go i usaly find them in the american cars.
thats what i am planing to do to save my a$$ some mony.
Old Jun 30, 2004 | 02:29 PM
ASHURA's Avatar
that works, last time I even grabbed a FMIC off a turbo Starion (and that thing is huge)..
1 oil cooler that's readily available is from the 89 (AE92 series) corolla GT-S..
however, if you're looking more along the line of what Summit offered, the 90-93 Accord actually got those as P/S fluid cooler, finned.
Old Jun 30, 2004 | 10:00 PM
Niku-Sama's Avatar
eh, i'd rather have something new unless i could find something that had a fan and sensor on it that operated on its own, so unless i could get a good haul in a junk yard i want something new.
i did the transmission fluid today, forst time i have ever done it but i have only put 10,000 on it since i bought it a year or so ago, our transmissions are every 30,000 for the autos, it hadnt been done ever i dont think. it came out pitch black and i have a jack *** co-worker telling me i could kill the transmission by putting new fluid in it and i kinda thought to my self i'm going to screw it for sure running old fluid in it (i work in a lube shop so i do this stuff alot)
i want a cooler so i can extend the life a couple of miles more
Old Jul 1, 2004 | 05:46 PM
ASHURA's Avatar
which reminds me when I changed the tranny oil in my other car... it has the viscosity of water, it just pours out within seconds... don't think it's been replaced either.. pitch black too.. Even warm 75w90 won't have that viscosity..
Old Jul 4, 2004 | 10:20 PM
Niku-Sama's Avatar
75/90 A.K.A. GL5 wont get black unless its been in there and abused hard core for about a decade, fords run standard GL5 in the front and rear differentals and the first service date is 100,000 miles unless you tow alot then its about 60,000 miles, it should only be used in maunal transmissions, if you have GL5 in your auto tranny then somethings a little....not right.
but yea on the manual thered be a drainplug and a check plug, you undo both when you exchange it, put the drain plug in and fill through the check plug untill its about full up to the bottom of the check plug.
ATF goes black pretty quick but the stuff from my car was like dark matter black, you could have used it as pen ink
tarun900
19
Dec 20, 2021 06:57 PM
Pied
Sep 26, 2015 03:29 PM
