suspension rattle
Old Aug 24, 2004 | 01:49 PM
cardana24's Avatar
Blown
suspension rattle
I am getting rattling from my PS rear suspension. I dont know what it is. The gland pack nut is on there super tight. And when I reach in and shake the spring I cannot simulate the noise. When I go over small bumps I get a rattle coming from the passenger side rear, it has been doing this ever since I changed out the struts (and getting worse)...but none of the other ones do this. When I replaced the struts I only replaced them and nothing else...when I put them back together I used what was left of my bump stops and dust covers. Anyway has anyone had a similar problem?
-Carson
Old Aug 24, 2004 | 02:19 PM
mrc0mputer's Avatar
-Carson
I had this problem, but it was in the front. It was a broken/cracked mounting plate.
Old Aug 24, 2004 | 03:09 PM
86Wagon's Avatar
Carson,
My car did this as well after a shop had replaced the strut cartridges
in the rear of my 86 wagon.
What it turned out to be was the cap nut over the strut cartridge that
was coming loose creating a rattle.
I'd take the car back and they tighten it up, but it would make noise
again after a week's time. This went on for about a month when I finally
said "enough!".
I called the dealer and explained the scenario to a tech there and he
asked me if the shop used locktite on the caps... the shop said no...
the shop backed the nut off enough to expose some threads, applied
locktite and tightened'er down again, that was over two years ago and
no rattle since!
Scott
Old Aug 25, 2004 | 05:16 AM
cardana24's Avatar
Blown
ok I will look into this when I pull my suspension apart again which should be in a few weeks....I want to lower the car so hopefully that will be sooner than later and I can get a better Idea of whats going on
Old Aug 25, 2004 | 07:51 AM
maximase86's Avatar
I love lamp.
Yeah, sounds like a loose bolt back there. I have one the nuts for my struts won't tighten all the way because the whole insert rotates. So the little washers under it rattle because they aren't completely tight.
S
Old Aug 25, 2004 | 08:34 AM
cardana24's Avatar
Blown
ok, it sounds like something I will just have to fix once I pull the entire suspension out....I will get under it again probably tomorrow night and try to find exactaly where it is coming from...but like I said I cannot simulate the sound by shaking the spring on or jumping on the rear bumper.
user 11122324
42
Jul 18, 2022 03:35 PM
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
