"Crying fuel pump" Good brand for fuel filter?
Old Sep 22, 2004 | 12:35 PM
Geza's Avatar
Do you guys know a good brand for fuel filter and ones that should be avoided?
Recently my fuel pump started to make some whining noise, not all the time, just several times a day for a minute or two.
I have had the fuel tank hoses replaced recently at a shop, I don't know if they did something that could cause this fuel pump to cry.
Geza
Old Sep 22, 2004 | 06:00 PM
max95q's Avatar
Whining noise means that you could be in need of a new fuel pump. Is it loud or more of a humm noise.
Old Sep 23, 2004 | 09:30 PM
Geza's Avatar
It is loud. But the pump emits this sound for 20-30 seconds, then it stops and you might not hear it for an hour. So, it comes on really intermittently.
Geza
Old Sep 23, 2004 | 11:52 PM
(_8*(l)Homer's Avatar
I can only hear mine pump when the ignition is switched to 'ON' for about 10 seconds.
Old Sep 24, 2004 | 03:57 AM
ukfan4sure!'s Avatar
The intermittent whining you are hearing is a sign of emminent failure of your pump and you should replace it at your earliest convenience. Trust me, I know....ahem....not a good day, that one...
Old Sep 28, 2004 | 10:54 PM
Geza's Avatar
Do you know if the fuel pump can be removed from the fueltank (through the hole underneath the rear seat) without removing the fueltank?
Old Sep 29, 2004 | 08:00 AM
max95q's Avatar
Yes, it can that is how you replace the fuel pump. It should not be hard. Just disconnect the relay behind the back seat it is either green or blue cant remember. Pull the fuel pump fuse from the fuse box and start the car and have it run until it turns off on its own. Take the keys from the ignition and remove the rear seat and get to work. It shouldnt be hard.
Old Sep 30, 2004 | 12:44 AM
Geza's Avatar
Max88q,
Do you know, what other parts around the fuelpump assy. are recommended to replace at the same time? Any (primary) filter if any, or anything else?
I looked up fuelpump prices on the Internet, they are around $113, Bosch, most of the time, it is mentioned as "fuelpump ONLY". I guess, you can also buy the whole enchilada (fuel level sending unit too), but I have no problem with the sending unit.
Geza
Old Oct 1, 2004 | 10:41 AM
keith_u's Avatar
Mine was makin noises like that and it ended up not being the fuel pump it was the fuel pressure regulator.This mey be your case too and it is alot cheaper to fix.
Old Jul 15, 2005 | 03:57 PM
Xservice0183's Avatar
How do you know if its the fuel pump making the noise? I get a noise when i turn on my car, but I thought it was my starter needing degreasing which I dont want to do, but if its the fuel pump, might be simple, they have a $89 in the GB Section.
Old Jul 16, 2005 | 04:45 AM
max95q's Avatar
You'll hear a humming noise coming from the back of the car that is loud. Not a bearing noise but an actual hummmmmmmmmmmmm.
Old Jun 4, 2006 | 10:19 AM
msnewton's Avatar
And what about this sound come from the front, around the manifold...
Along with this... the engine after starting drop down to nearly die then it comes up to normal..!!!
Any help ....
MAX2000
Old Jun 4, 2006 | 04:01 PM
keith_u's Avatar
ok if I remember right on my old max it was the fuel pressure regulator that was doing that.
Old Jun 6, 2006 | 08:43 AM
Theindigo88
Has any one ever put a walbro 255 in a 2nd gen? Do they work well ?
Old Jun 6, 2006 | 09:30 AM
Xionide's Avatar
The EXACT thing happened to me. I replaced the pump and it still squeeked like a stuck pig. I replaced the Fuel pressure regulator and problem solved. I would definately recomend that people replace that part first before putting in a new fuel pump.
Old Jun 7, 2006 | 10:08 AM
msnewton's Avatar
Thanks,
Any idea if I can replace/repair this regulator by myself or I should go for the dealer...!!!
Regrads.
Old Jul 12, 2006 | 07:51 PM
neo_densetsu's Avatar
Thats what happened to my fuel pump, it was whining, then it died... Just today I got a excelent fuel pump out of an 86 maxima at the junk yard for $5. I did not know there was a major difference on the fuel pump and tank's from 85 to 86... the new one didnt fit, I tried swapping out the motor/pump into the old mount, but the electrical connector snapped off....
Check the junk yards, I got mine for $5.
As far as a Fuel Filter, I ALWAYS go with the offical NISSAN OEM fuel filter. The price is usually no different than a different brand.
If you want, you can install an Aftermarket fuel pump, You will just have to modify the mounts for it. I saw somewhere on a Z site, that someone was modding the mounts in a Z31 for an aftermarket pump. I will try looking for that link.
Hope this helped some..
Old Jul 13, 2006 | 02:56 AM
msnewton's Avatar
Help please... nobody telling me the answer...I'm waiting for your kind support.
Old Jul 13, 2006 | 06:31 AM
keith_u's Avatar
yes this is something you can do yourself it is three hoses and two bolts it is just a really tight fit getting to some of the stuff.
Old Jul 18, 2006 | 01:22 PM
HowlerMonkey's Avatar
Make sure it isn't the power antenna if yours doesn't raise or lower the antenna.
Old Aug 31, 2007 | 10:40 AM
ALANLJ21's Avatar
I have a 5th gen 04 maxima. Mine was whining from the front and it turns out that it was some dampers for the fuel pump. Anyway it cost to 300 bucks to fix.
Old Aug 31, 2007 | 05:22 PM
vernk's Avatar
Would a pump out of a VG 3rd gen work?
Old Sep 1, 2007 | 02:01 PM
benalcoa's Avatar
it should work.
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
homeyclaus
Sep 3, 2015 06:15 PM
95Maxi
Aug 29, 2015 09:38 PM
homewrecker
Aug 24, 2015 08:56 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
