I have an 1986 Max, and I was told by the emgine diagnosis, that I needed a Crank angle sensor thats located inside the disributor. Because the car wouldn't start.
Well I went to a junk yard and got one (a distributor). Because they wouldn't sell the Crank angle sensor without it. (The Distributor) I dont think it worked. I went back and got another that looked to be in better condition, I dont think that work either. Now keep in mind that the car turns over beautifully. Then someone said to me that after I change the disributor, I have to do somthing else to get it started. Anybody know what that is? maxima_86@yahoo.com |
Since you removed the stock distributor did you set the engine at TDC? If you didn't put the #1 cylinder at TDC, during the install of the distributor your ignition timing will be way off.
Thanks. Do you have any idea how to reset ithttp://forums.legend.org/icons/icon5.gif
© 2024 MH Sub I, LLC dba Internet Brands
