Parting out my 1987 Maxima
Mar 22, 2005 | 05:59 PM
  #41
Do you have the drivers side window motor?
Mar 22, 2005 | 08:44 PM
  #42
Very appreciated man. THank you.
Mar 23, 2005 | 10:27 AM
  #43
how much for the FPR shipped to Virginia (22901)?
Mar 23, 2005 | 10:44 AM
  #44
My girlfriend's Max needs a new injector. How much are you asking for one?
Mar 23, 2005 | 06:12 PM
  #45
Cardana24,
FPR? Fuel Pressure Regulator? If that's what you mean it's $23.50 shipped.
Mar 23, 2005 | 06:18 PM
  #46
Quote: My girlfriend's Max needs a new injector. How much are you asking for one?
$35 shipped but I would check to make sure the replacement part will work in conjunction with your existing injectors. Mine are new-replaced by Nissan. You should be able to get Nissan to replace all of them for free as part of the recall on injectors if this hasn't already been done to the car.
Mar 23, 2005 | 06:19 PM
  #47
Quote: Do you have the drivers side window motor?
Have it. $15 shipped.
Mar 24, 2005 | 05:27 AM
  #48
ok, is it already off the car? The main thing I need on it is for the fuel temp sensor to be in good shape (the thing that screws into the side of it and has a spade connection). Let me know the condition and when you can send it out to me. Thanks.
-Carson
Mar 26, 2005 | 04:35 AM
  #49
Quote: Voice module works. I'll check to see what other parts there are. Will get back to you.
The voice module has the repeat and on/off switch. It connects through the harness to the speedometer speed sensor, door switches, left front speaker, fuel tank sending unit, parking brake switch, light switch. I can scan the page from the factory service manual when i get a chance.
Mar 26, 2005 | 10:56 PM
  #50
That would be stellar if you could scan that for me. I haven't had the best of luck finding any info about that box. Thanks man.
Mar 27, 2005 | 04:34 PM
  #51
Quote: $35 shipped but I would check to make sure the replacement part will work in conjunction with your existing injectors. Mine are new-replaced by Nissan. You should be able to get Nissan to replace all of them for free as part of the recall on injectors if this hasn't already been done to the car.
Was there a TSB or TSR on them or something? If so, I'm going to have to find out if they've been replaced yet.
Mar 27, 2005 | 05:57 PM
  #52
Quote: Was there a TSB or TSR on them or something? If so, I'm going to have to find out if they've been replaced yet.
It was an actual recall. Nissan can check if its been done by the VIN.
Mar 28, 2005 | 07:50 PM
  #53
I could use some Slash pannels, if you have them still. Also, does it have the adjustible shocks? If so what do you want for the them? There is a little sensor on the rear side of the block, next to the oil filter, the oil pressure sensor. That too. The crank shaft pulley if you have it, I need the one that uses ribbed belts not the v shaped. I think that is it, I may think of something else. 83353 is the zip.
