cold start/running problems...
Old Feb 18, 2005 | 09:20 AM
Dayle97SE's Avatar
I recently bought an '87 max with only 88K miles. For the most part everything looks an operates very well. Recently though I have been having problems with cold starting
(cold meaning engine has completely cooled down, overnight, etc.), its takes a long time cranking and a couple of tries before it starts. Then after about a minute it starts to hesitate and stalls out repeatedly. After the engine fully warms to operating temp though, everything is fine and it runs fine. Anyone have this problem before?
Old Feb 18, 2005 | 09:46 AM
cardana24's Avatar
Blown
if it is running fine once it is warm I would check out the AAV (a.k.a air bypass valve), there is a sticky on how to fix it....its a common problem with second gens.
Old Feb 18, 2005 | 10:23 AM
Dayle97SE's Avatar
do you mean the air regulator, because I already replaced that with a brand new part
Old Feb 18, 2005 | 10:32 AM
cardana24's Avatar
Blown
ok, did not know that. Next I would check the ecu for codes and see if your injector recall has been done.
Old Feb 28, 2005 | 05:42 AM
80land's Avatar
cold starting
Ihave been experiencing the same problem here and i did a few things which might be of help.Since you already changed the air regulator check your throttle position sensor switch and last but not the least is the cylinder head temperature sensor.I took mine to the dealers and they told me that the cylinder head temperature sensor is corroded and that is my next project for the next sunny weekend.
Old Feb 28, 2005 | 05:43 AM
80land's Avatar
For your information the injector recall is not going to fix your cold start.
Old Feb 28, 2005 | 08:07 AM
Drjmaxx88's Avatar
Check you battery first. Then the starter. Then the EGR valve. If any of these aren't working(or all of them) they can do this to your car. Always start with the cheap easy stuff before you go getting the CHTS replaced. By the way if you have the means to get it done you should probably get a new water pump and timing belt while everything is off. Also when you get a CHTS replace the harness too. Just so you don't have to go back and do it later.
tarun900
19
Dec 20, 2021 06:57 PM
TKHanson
Nov 24, 2018 01:39 AM
yamehoo
Sep 24, 2015 10:21 AM
msellas
Sep 23, 2015 09:16 PM
