My 87 Se and a few ?'s
Old May 5, 2005 | 05:59 PM
SurraTT's Avatar
HR Swap Pioneer
i just got the car, i have a few questions
My suspension switch (S N F) keep on flashing, i replased he switch before i replaced it i would change to a setting it would flash then stop (i assumed it was ajusting while flashing then it stopped) but now i cant get it to stop so i guess its not adjusting right.
my factory radio fm was gone so i put a regular radio in, how do you make it look right, i coulten find a kit for it.
where is the best place to run amp wire throught the firewall??????????
im sorry for the bad grammer and all the questions but i am a noob, thanks for any help.
Old May 6, 2005 | 05:31 AM
cardana24's Avatar
Blown
I did not run my amp wire thru the fire wall, but the people that do this usaully run it in around the clutch pedal. For your aftermarket headunit you can get an install kit thru crutchfield, that will fill the gap that the switching from the factory head unit leaves.
When you susupension is flasing like you are talking about it just means that its not working. When I bought my car it was doing this so I just replaced mine with no adjustable suspension.
Old May 6, 2005 | 10:58 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
there is a hole inb the firewall below the brake booster cylinder un bolt it and then feed your wire through there and run it through the door sill at the bottom below the carpet i done it to replace the battery to the trunk.
Old May 7, 2005 | 05:07 AM
SurraTT's Avatar
HR Swap Pioneer
oh ok thanks
