wheel offset ?
Old May 9, 2005 | 11:15 AM
cardana24's Avatar
Blown
wheel offset ?
Hey guys I searched around some for this but did not find anything that would answer my question. My question is, would a 17x7 with a 40mm offset fit on my 87se? Would it rub the fenders? I am no wheel expert so please let me know if you are good with this stuff.
Old May 9, 2005 | 01:18 PM
MaxWgn's Avatar
That should fit...IIRC, the stock offset on our 15X6 wheels is 40 also, so 40 on a 7 should be ok, without any major problems, but I could be wrong...
Old May 9, 2005 | 01:39 PM
maximase86's Avatar
I love lamp.
I have 18x7.5 with a 40mm offset, they fit perfectly. Only rubbing I get is from the inner splash shield of I crank the wheel all the way. I'm also running 215/35/18 tires.
S
Old May 9, 2005 | 01:45 PM
cardana24's Avatar
Blown
[QUOTE=maximase86]I have 18x7.5 with a 40mm offset, they fit perfectly. Only rubbing I get is from the inner splash shield of I crank the wheel all the way. I'm also running 215/35/18 tires.
I'm going to start calling you rubber band man!! I was running 235/40/18s. But now I am streching my tires a little with a 235/35/19 on a 19x8.5
Old May 9, 2005 | 05:26 PM
SurraTT's Avatar
HR Swap Pioneer
im looking to get some wheels, but i wont 4 lug wheels not the ones with a lot of holes all the way around , so i guess it will fit 4 5 lug , i just wont 4 lug 5 spoke 17''
Old May 10, 2005 | 05:20 AM
cardana24's Avatar
Blown
you can get those, they are just harder to find. The ones you are talking about usually do not have patterns for 4 and 5 lugs on the same wheel but rather two different patterns for the number of lugs. All the wheels I have put on my 87 have been 4x100/114.3. Since we need the 4.5" then alot of times I have to deal with the wheel also having the 4x100 holes.
Old May 10, 2005 | 07:39 PM
SurraTT's Avatar
HR Swap Pioneer
i have really noticed now that a lot of cars in magizines have the wheels with a lot of holes. do you think its best to buy weels and tires in the same package??? thats what im looking for.
Old May 11, 2005 | 05:18 AM
cardana24's Avatar
Blown
Yes, you will probably get a better deal if you buy the wheels and tries as a package, because when you do this the wheels with come mounted and balanced.
Old May 17, 2005 | 02:17 PM
BigEnos's Avatar
This is semi-related. Will a Nissan Sentra (like a current Spec V) rim work on a 1985? Seems like it should, but it seems like some Sentras are 4X100 and some are 4X4.5". The Maxima is 4X4.5 right?
Specifically I'm looking for a set of these:
For my 1985 SE.
Thanks for the help.
BigEnos Burdette
Old May 17, 2005 | 03:41 PM
maximase86's Avatar
I love lamp.
The spec V rims will work. They are 4x114.3 just like the 2nd gen. I don't believe any of the sentra wheels are 4x100mm.
S
Old May 17, 2005 | 07:35 PM
SurraTT's Avatar
HR Swap Pioneer
so when im shopping for wheels om looking for
4x114.3
40-45 offset
i wont 17's
7 wide?
6 would be fine with me
9where is the best place to buy wheel tire package pre blanced valve stems etc...... i looked at ebay but it would be about 900 with shipping, i wont more 500-600 range
Old May 18, 2005 | 05:17 AM
cardana24's Avatar
Blown
ebay should have plenty of sets in your price range, you may have to get them used though. Also you can check places like wheelmax.
4x114.3
40-45 offset
i wont 17's
7 wide?
Old May 18, 2005 | 05:25 AM
BigEnos's Avatar
4x114.3
40-45 offset
i wont 17's
7 wide?
Lots of 17" spec V rims on Ebay, they even say "Nissan" on them. Would probably look great on a 2nd gen, but I use my car as a "beater" and potholes + theft are an issue. I've seen sets of 17" spec V rims for the $400 range and you could easily get tires for $250. If you can find some with used tires already on you'd be right in your range.
Like This
and
This
Good luck!
Old May 18, 2005 | 05:30 AM
BigEnos's Avatar
S
Thanks for the info. The old sentra, like the original se-r (early '90s) had 4X100mm. That's why I was seeing both show up on searches.
Old May 18, 2005 | 11:54 AM
maximase86's Avatar
I love lamp.
Ah, I thought you were refering to newer sentra's.
S
Old May 18, 2005 | 12:25 PM
SurraTT's Avatar
HR Swap Pioneer
i wasent really relating to spec v wheels but now that i see them ill probally go with something from a Nissan, thanks a lot
Old May 22, 2005 | 01:26 PM
Maxima Diesel's Avatar
What size bolt pattern does the first generation Maxima use? I do know that they are 4 lug rims. Don't remember, but I think I recall reading somewhere that the second generation is the same as the first generation. Also, where could I buy 17x6" or 17x7" rims for a first generation car? I guess 17s will fit without any modifications and no rubbing?? I haven't tried to search Ebay for rims, but the reason why is because I don't know the exact bolt pattern size of the 81-84 Maxima. And also don't want to buy a nice set of rims just because they are a 4 lug pattern. I know almost every Honda runs 4 lug rims, but are they applicable to fit the first generation Maxima? Thanks for any help.
Salvy
Old May 22, 2005 | 08:09 PM
wylie-c's Avatar
First gen is the same bolt pattern as second gen. Not sure on the offset though. I had 280ZX "Iron cross" rims on my first gen. No rubbing.
Fbana41
Aug 29, 2016 12:18 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Andy29
Sep 29, 2015 05:32 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Redfox
Sep 28, 2015 10:41 AM
