2500rpm sputter
Old Aug 29, 2005 | 12:04 AM
mclarengts1's Avatar
2500rpm sputter
I got my 87 running and now when i hit around 2500 rpm it sputters till about 3500 then it good ... any ideas why?
Old Sep 4, 2005 | 12:58 PM
bump ... anybody know
Old Sep 4, 2005 | 04:25 PM
gen1's Avatar
Suspect MAF problem. Check
http://www.talkaboutautos.com/group/...ges/46709.html
-bob
Old Sep 4, 2005 | 06:07 PM
max95q's Avatar
Thats what I was thinking. check that
Old Sep 4, 2005 | 06:20 PM
maximase86's Avatar
I love lamp.
I'd also pull ECU codes, as well as check the EGR valve.
S
Old Sep 11, 2005 | 09:43 PM
ok thanks i'll look into those ... because now its like when i let off the gas or come to a stop, and then hit the gas again it sputters bad
Old Sep 19, 2005 | 12:10 PM
ColombianMax's Avatar
I had somewhat of a similar problem on my new 3rd gen except it didnt get past 2000 RPMs and would feel rough if you hold it at 2000rpms but it turned out to be the timing belt. Good luck with yours, I also thinking it might be the MAP or injectors maybe?
Old Sep 19, 2005 | 10:36 PM
UberZogster's Avatar
Heh mine won't stay running unless i hold the gas when it is cold. Even when it is warmed up it tends to die at stop lights when i hit the gas.
bryants95max
Oct 2, 2015 12:52 PM
blakkrob
Oct 10, 2002 07:47 PM
Jopa416
Sep 20, 2002 12:58 PM
CandiMan
Jan 26, 2001 12:30 PM
