rear brake differences
Old Sep 17, 2005 | 06:50 PM
Niku-Sama's Avatar
ok i am kinda curious, i finally just did my rear brakes and i was excited to use my brembos but i couldnt because they sent me the wrong rotors so i had to have mine turned (0.3220 is the thickness on mine now).
any way mine being bulit in 1/87 has the bearings that slide into the rotor and the rotors has machined spaces inside the center opening to act as a hub....the rotors i got do not have this...
my question is what rotors did i get?
are they wagon, or rotors for cars 7/87 and up?
or did some one change my rear brake set up?
Old Sep 19, 2005 | 03:50 AM
SurraTT's Avatar
HR Swap Pioneer
idk but i seen my rear roater and they are way diff that the front, really small and like only 1 side has a pad
that prob dosent answer ur ?
Old Sep 19, 2005 | 05:30 AM
max95q's Avatar
I think they sent you the wrong ones. Did you make sure they didnt send you two front ones? Im boggled.
Old Sep 19, 2005 | 10:05 AM
Niku-Sama's Avatar
they arent 2 fronts, they arent vented. good news is i found the USB cord to the camera i borrowed so i'll take pics...and yea i know they sent the wrong ones but the question is to what car do they go? (i.e. can i pawn them off on some one here)
Old Sep 19, 2005 | 05:03 PM
Niku-Sama's Avatar
ok pics
Front
Rear
yea i know a stud it out, it got knocked out in shipping
Old Sep 19, 2005 | 10:01 PM
max95q's Avatar
It doesnt give you a name for what car it is for or nothin, man usually on something they would have atleast Nissan Max or something I would think. I wonder if it is for a 240sx. The early model 240's like the ones you see running around have the same bolt patterns as our cars I believe. Just a thought.
Old Aug 24, 2009 | 10:06 AM
bowtie72's Avatar
Rear rotors
These look just like the ones I took off last night. You will need to take your old bearing races out and install them in the new rotor. Or you can buy new ones and install them if you do that you should replace bearings too. They should come in a set.
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
egali045
Aug 16, 2015 01:19 PM
RealityCheck
Aug 5, 2015 06:18 AM
