rebuilding the "87"
rebuilding the "87"
took the max to the shop for diagnosis. i need a Full tune up, (plugs wires, thermostat, belts hoses oil change0. big things are water pump, new seals, timing belt, full exhaust, motor mount, rt ball joint, tension belt, shifter cable. looking at 1200 forall work and parts. going with ngk and msd for ignition spark. any suggestions?
uhh, most of thats top end work, i dont see any thing about main bearings, rear main or what not.....have you thought about doing alot of that work your self?
plugwires, belts and hoses, and oil change of course are the easiest to do...save you some bucks there....
that way unless its a screw you shop your only charged with the water pump even if they take the belts off and you should do a timing belt, having it done by some one isnt such a bad idea because if you do it wrong you can be out of a motor.
also, what do you mean by new seals? gaskets or something or are you getting blue smoke?
need help with some wiring
sry to use ur post for mine but i can't make my own thread. but neway i have a 1987 max(named Veronica) and my uncle was the previous owner and he tried to install a stereo himself without knowing what he was doing. well short story
long, he screwed up the wiring so now the security system is putting a draw on the battery and unless u undo teh batt. cables, it'll be drained in a about a day. So do ne of ya'll have ne ideas on what to do? try to keep it cheap please. thanx
If you are going to need all those parts, I would rebuild the enigine as SuraTT said. Also you should rebuild the transmission. Hate to do all that nice engine rebuilding than the transmission goes out. Does the car need shocks/struts? Are the springs sagging?
to be honest from my stand point he doesent need a rebulid, most of those things hes talking about get replaced a few times before the internals begin to wear out. other things you need to change regularly
belts, hoses, oil, thermostat, timing belt need to be replaced regularly. ball joints, exhaust, motor mounts, water pumps, alternators, coils, rotors, distributer caps get replaced a few times before you need to tear down an engine...unless your stupidly harsh on your engine
as for wiring problem guy, go get a manual (factory service or chiltons) and then start sifting through the wiring....i would check in the back with the rear speakers first and then the head unit...security box is in the back bolted under the 3rd brake light in the trunk
yeah i don tthink i need a rebuild. the guy at the shop has always been trustworthy. he checked everything and said my engine and tranny were solid. i was looking at a long block for about 1600. but now thats out. the interior will be next month sometime. would like to have leather seats; racing seats are an option.
i'll sell you mine...theyre origonal leather 87 seats...not one doesent have a tear in it
gotta skip
thanx for the tip Niku. Also i have a skip. i and some other people think it's either a fuel injector or possibly a valve. but then my dad said something about the distributor. What do ya'll think it is?
rebuild
Finally about to get my 87 back. after all the work i still needed another motor mount, rack/pinion boot, new tire and small adjustments. it still has a small leak,( i believe at the rear main seal). hope i get it by friday. i installed ngk iridium and ngk wires. i am gonna run castrol full synthetic when it finall gets home.
James92SE
142
Jan 2, 2024 09:23 AM
Apr 16, 2020 05:15 AM
Mar 12, 2020 12:06 AM
Pied
Sep 26, 2015 03:29 PM
