How do I pull the door panels off to change speakers?
Old Oct 6, 2005 | 09:58 PM
lowandslow88's Avatar
How cuz I dont wanna break anything getting em off...
Old Oct 7, 2005 | 03:51 AM
SurraTT's Avatar
HR Swap Pioneer
get a haynes manuel dude
Old Oct 7, 2005 | 03:20 PM
maximase86's Avatar
I love lamp.
5 screws, 2 harnesses and panel poppers.
S
Old Oct 8, 2005 | 10:06 AM
kiwikev's Avatar
remove the screw cover inside the door pull handle, then remove the screw. slide the handle to the rear of the door and remove. under that are two screws holding the panel on. remove those. at the top right corner of the panel is a triangular shaped piece of plastic trim. remove the centre of it by popping it out with a screwdriver, then remove the screw under it. remove the triangle trim, then pry the panel away from the door which is secured by several panel poppers around the outside, then just slide the panel upwards to disengage the clips at the top of it.
Old Oct 8, 2005 | 11:58 AM
kiwikev's Avatar
sorry, forgot to include that you need to pop off the plastic trim around the door release handle
MikesChevelle
Audio/Video/Electronics
Sep 11, 2016 06:36 PM
vingodine
45
May 21, 2016 12:46 PM
Abdelrhman
Aug 17, 2015 12:16 PM
RealityCheck
Aug 5, 2015 06:18 AM
