Cylinder Head Temp Sensor Replacement on 1987 w/ VG30E
Old May 25, 2008 | 08:31 AM
Edge's Avatar
I have an '87 where the cylinder head temp sensor has gone bad. Has anyone replaced this without removing the timing belt as stated in the service manual? It looks like there might be enough room to change it out if the idle pulley bracket, stud and timing belt cover are removed.
Old May 27, 2008 | 12:09 PM
maximase86's Avatar
I love lamp.
I have not tried with the cover on. Though I believe you can...you might need to move the cruise control unit, maybe the thermostat cover. You should be able to do it. Might even use a extension and u-joint.
S
Old May 27, 2008 | 03:57 PM
vernk's Avatar
I'm not sure but unless your timing belt has been changed that you know of, if you have to remove the cover, change the belt while your in there or it just has to be done later and if your at 65k it's about time anyways.
Old May 28, 2008 | 12:51 PM
Edge's Avatar
S
But you were able to replace it by removing the t-belt cover, cruise and t-stat fitting?
T-belt was done about a year ago. Unfortunately, I didn't replace the sensor then.
Old Jun 6, 2008 | 06:02 PM
irish44j's Avatar
retired moderator
moving to the 1st/2nd gen forum, where you might get more responses.
Old Jun 7, 2008 | 03:21 AM
Big_E-Dog's Avatar
2nd Gen Boostinator
get a 17mm or 19mm deepsocket 2 inch extension take the cruise controol thingy out, the resivor for coolent, and unplug it and trench it out. you do not need to remove the timing belt cover but if you do i hope you have octupuss hands because those lil 8mm bolts are a byiotch.
Old Jun 12, 2008 | 01:16 PM
AzureblueZ's Avatar
This is what we do in the 84-89 300ZX's:
http://z31.com/repairs/chts.shtml
It's the same motor so it should work. I've tried this and it does work.
That being said if you haven't changed your timing belt in a while it's always a good idea. In the process of doing that job this will be totally accessible.
Edit: Just re-read and you said you did do the timing belt. Nevermind then
Good luck!
vingodine
45
May 21, 2016 12:46 PM
raffivegas
Aug 23, 2015 09:54 PM
FlaMark
Aug 21, 2015 11:06 AM
doobadoo
Aug 15, 2015 06:43 PM
yat70458
Aug 3, 2015 01:16 PM
