front brake pad replacement?
Front pads are easy. With the front end up in the air, and the wheel off, look at you caliper. You will notice two bolts holding the caliper to the mounting bracket, via the two floating pins.
At this point, compress the caliper with a large C-clamp, channel-locks, or a pad spreading tool, to push the piston back into it's bore.
Then, loosen the bottom mounting bolt, and 'flip' the caliper up, and you can actually let it rest on top of the rotor.
Paying attention to the orientation of the little metal clips that hold the pads into the bracket in case you find yourself removing them. For a simple pad replacement, you shouldn't need to.
Pull the old pads from the bracket and clips, noting their orientation, and the fact that the pad with the wear indicator goes towards the center of the car, and now insert the new pads. This may take some finesse, as they do fit snuggly, and can by trying to install the first time around.
'Flip' the caliper back down, and reinstall the bolt. Now, reinstall the wheel, and drop to the ground.
Take for a road test, and try a couple of hard panic stops to help seat the new pads...
Originally posted by TacoBill
Thanks MaxWgn for the info!
Do you suggest OEM pads or will a generic set from an auto parts store (Pep Boys, Autozone, Kragens, etc.) will do?
The thing to remember is, always use the semi-metallic, no matter what. I personally have not been able to try the good pads, due to budget constraints. I have, however, had good luck with the $17 OEM quality set.
The funny part about your post is, I just had a caliper go bad, and it had worn the almost new pads on the right front down to the metal before I could get the time to fix it. Last night, it fully seized down, and almost wrecked the rotor...so there I was, in the dark, changing out a caliper (I'd recently bought one to replace this one with, as the bracket on my original was messed up.), and pads...now THAT'S what I call fun!
vingodine
45
May 21, 2016 12:46 PM
03VQMAX
Sep 25, 2015 04:19 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
RealityCheck
Aug 5, 2015 06:18 AM
