Error Code 44
Old Jun 24, 2002 | 11:32 AM
i_canoe's Avatar
Error Code 44
Clear memory after repair, run the engine to warm. Set the computer to mode three and I get a 44 error code. Never seen it before and no books decribe it. Will the computer from my 85 work in my 87
Old Jun 24, 2002 | 01:10 PM
Charles Bisel
Yeah, my Chilton's manual doesn't list a code 44 in it. You may be able to use the '85 ECU in your '87 as long as they both have the same tranny (auto/manual). I don't think that you can swap ECU's if they have different trannies. Also, there is a difference between the California ECU and the one used in all other cars, so you may get error codes 32, 35, 45, and 51 if you put in a CA ECU in a non-CA car.
-C-
Old Jun 25, 2002 | 12:51 PM
Nismo87SE's Avatar
Re: Error Code 44
IIRC code 44 means no malfunction is stored, basically your all clear .
Old Jun 25, 2002 | 04:23 PM
i_canoe's Avatar
Re: Re: Error Code 44
I know 55 means all OK with red and green sequence, but what is IIRC?
Old Jun 25, 2002 | 06:11 PM
i_canoe's Avatar
Re: Re: Re: Error Code 44
Oops, just pulled the ecu from the 85. Them good ole boys at Nissan put an error code list on the top plate. Yes 44 is all clear. No 55 is listed as in my Chilton manual. They may tried to cover too many years or it just a miss print? Thanks for all the replies and MaxOn!
Old Jun 25, 2002 | 08:22 PM
Nismo87SE's Avatar
Re: Re: Re: Re: Error Code 44
Code 55 is for the 89 and later nissans, code 44 is all clear for the 84-88 nissans. Also IIRC means If I remember correctly.
Old Jun 25, 2002 | 09:22 PM
Charles Bisel
Mine reports a code 55 when mine it is all good, and it's an '88.
-C-
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
