I got the Maxima!!!
Picked up my '93 SE today finally. Very nice car - nice on the freeway. I'll post pics as soon as I can. Quiet, comfortable and adequate power. Hopefully more will be on the way...
Things I need to do:
Adjust clutch
Fix brakes
Figure out why power locks click but don't work
-Jacob
'93 SE 5spd. Met. Blue
Adjust clutch
Fix brakes
-Jacob
Describe the power locks problem... my door locks are kinda fussy to unlock from outside with the key. I have to hold the key in the unlock position while opening the handle to get the door to open, otherwise the door will lock back up. This is usually when it's cold out.
You got the BOSE tape only or CD/tape deck?
Pictures???
I am now home in NY for the next couple of weeks. Got to drive the ol' 84 Celica around a bit. Sweet!
Pictures???
Pictures???
Pictures???
It has the Bose speakers but the owner put a Pioneer Tape deck/CD changer and a 6 disc changer in the trunk. Not the best stuff but it sounds good for now and was all professionally installed. I wouldn't mind getting a Bose CD head unit and keeping it stock.
Other than that, I'm gonna try and throw my '86T 300ZX whels on and see what it looks like - it will probably be screaming for some Eibachs. MMM. I also hafta adjust the clutch and see about findign a battery. It will need rotors, pads and maybe a master-cylinder and then it's done. For a while. Love those gauges at night.
-Jacob
yeah sweet gauges... too bad the rest of the dash lights up all different colors but eh...
I go to college in Michigan but I'm from NY originally. I'm back in NY for semester break and the holidays. It's a fun 11 hour drive.
I think you jinxed me Jacob, as soon as I go out to my ar this morning, I hit the unlock button and nothing worked! Whereas they always worked before. After a while it worked again. I hear it's a bad lock timer unit.
You probably won't be able to put the BOSE stuff back in, you'll need the BOSE speakers and amps also. Each speaker has its own amp. It's great for a stock system but it still leaves some to be desired, mostly because there are so many problems with the BOSE (Clarion) head unit. It's kinda neat when it makes the power antenna go up and down doing a dance... I'm looking to upgrade it all soon
About the door lock problems
I thought my car was just possessed but it does similar stuff
It wouldnt let me out one time...id hit unlock, and it would lock right back. I had to take and manually hold up the lock (against the resistance of the solenoid) and get out.
Sometimes it'll lock itself out of nowhere too...but normally it'll unlock and stay.
It wouldnt let me out one time...id hit unlock, and it would lock right back. I had to take and manually hold up the lock (against the resistance of the solenoid) and get out. Sometimes it'll lock itself out of nowhere too...but normally it'll unlock and stay.
yet another electrical nuisance! sheesh, i am scared of the electrics in this thing. I had my door panel off today and sprayed WD-40 on the lock cylinder and all pivot points and such. The lock turns much smoother now but it still locks when you release the key. It's most likely the timer unit that does that too. ah, I can live with it until I fix it or buy a new one
DOH!!
I bought a battery tonight (well, two - just so happens the battery in Mom's minivan went out too) and suddenly my power locks work again. Maybe these were related?? I dunno - everythign else worked.
Ah well.
-Jacob
Ah well.
-Jacob
Hmm...batteries and door locks being related....
My car dosnt like me i think. I was doing some wiring and had to disconnect the battery...the doors were shut and keys in the ignition...pulled the negative battery cable off, did what i had to do, put it back on and *chunck* all the doors lock
its done this twice
Just thought id share that odd occurance
its done this twice Just thought id share that odd occurance
its done this twice
its done this twice -Jacob
Power locks. I had the same problem. I bought a used panel switch cluster $35 online. This wasn't the problem. It was a loose connect the the main panel. My mechanic fixed it last week. Unfortunately I was in a hurry and couldn't talk details. He's gone to vietnam for 3 weeks so if you can't find the fix, keep my email on file and in 3 weeks I'll update.
Where is the main panel?
If you could email me when you find this out, I would greatly appreciate it. My locks worked yesterday, but today they don't again (though I still hear the clicking noise under the dash). Any help would be greatly appreciated as I am planning on getting some sort of keyless entry system one of these days.
-Jacob
-Jacob
Goffery2uned
Aug 21, 2015 09:50 PM
julian888
Aug 6, 2015 04:39 AM
