shifter trouble
Old Jul 14, 2002 | 08:14 AM
daves's Avatar
shifter trouble
Please help...I have a 94 gxe and i have had a problem with my automatic shifter for about 6 moonths. When I place the car into drive from park, the car sits as if it is in neutral. Once i "giggle" the shifter downward while still in drive, the car will take off as if nothing has happened. once in drive, the car operates good, normally shifting the tranny. Can anyone please give me suggestions before I go to the dealer and spend a fortune???
Thanks,
daves
Old Jul 14, 2002 | 08:24 AM
darrick's Avatar
Dallas Nissan Enthusiast
ez as pie
your shifer bushings are bad you got two of em one on each end of the shifter cable the one that in bad shape is the one near the tranny but its so ez and cheap you may as well replace both just jack up you car and you will see a heat sheld under the shifter take out the 4 or 6 screws ant pop out the clip replace the plastic bushing and then do the one under the hood on top of the tranny it will take you mabe 30 min the bushings will be less than $3.00 at the dealer.
Old Jul 14, 2002 | 08:48 AM
daves's Avatar
Re: ez as pie
thanks for the help!!
Old Jul 14, 2002 | 11:48 AM
Michael's Avatar
Back in a 3rd Gen.
Re: Re: ez as pie
and here are the part numbers
34552-D4000
34407-01E00
they are only a couple bucks each.
Old Jul 14, 2002 | 01:42 PM
daves's Avatar
Re: Re: Re: ez as pie
34552-D4000
34407-01E00
Thanks for the part #'s
daves
Fbana41
Aug 29, 2016 12:18 PM
lux97Max
Sep 28, 2015 11:18 PM
atriuum
Sep 28, 2015 01:19 PM
zmcneely13
Sep 26, 2015 02:26 PM
