power door lock problem
Hey maxima guys, i have a question for you, My driver door lock has failed to work properly, If i hit the door look button all of the locks go down except for the driver side. I have to push it down by hand. I her the mechanizim working but the lock dosnt go down or lock the door, unless I do it by hand. Have any of you had this problem? If so what was the possible remedy? Thanks for your time..
Re: power door lock problem
Re: Re: power door lock problem
Door lock timer. Its a common failure on the Max. Its located under the driver side dash. You can either replace it or try and re-solder the loose connections if you are so inclined. Do a search, it has been discussed before.
Re: Re: Re: power door lock problem
I know for myself and another local guy (pj93max) none of the power locks worked at all when the door lock timer failed. After I resoldered them, all the power locks came back to life.
King_Ten_Ahead
Sep 30, 2015 04:27 PM
rbaker100
Aug 31, 2015 11:09 AM
shaunkey1
Aug 18, 2015 10:09 PM
kjm900r
Aug 5, 2015 07:14 AM
