attempting first brake job this weekend...
Old Jul 30, 2002 | 11:30 AM
Clayton's Avatar
I paid over 150 to have some powerstop x-drilled rotors and ebc pads installed earlier in the year and there has been so much damn vibration and pulsing since I am about to go crazy I figure it's time to start doing my own brakes. I am going to put my stock rotors back on to see if the vibration/pulsing stops. I just hope my EBCs are still in good shape. I could've bought a set of Brembo blanks and had them cryo treated for what I paid for these cheap a s s powerstops
This is my first brake job, so I hope everything goes smoothly. If I have enough time I may end up painting my calipers and drums too.
I'm pretty sure I have everything I need to do the job, but I'm open for any suggestions/tips or whatever for replacing rotors and maybe pads.
Old Jul 30, 2002 | 11:44 AM
pezking4's Avatar
Re: attempting first brake job this weekend...
Originally posted by Clayton94GXE
I paid over 150 to have some powerstop x-drilled rotors and ebc pads installed earlier in the year and there has been so much damn vibration and pulsing since I am about to go crazy This weekend, I am going to put my stock rotors back on to see if the vibration/pulsing stops. I just hope my EBCs are still in good shape. I keep thinking how I could've bought a set of Brembo blanks and had them cryo treated for what I paid for these cheap a s s powerstops
This is my first brake job, so I hope everything goes smoothly, and if I have enough time I may end up painting my calipers and drums too. I'm pretty sure I have everything I need to do the job, but I'm open for any suggestions/tips or whatever for replacing rotors and possibly pads.
-Clayton
I'll be doing my brakes this weekend as well. Good luck.
Old Jul 30, 2002 | 11:48 AM
JDwyer2821's Avatar
Re: Re: attempting first brake job this weekend...
About time Brake jobs are as easy as changing your oil
Old Jul 30, 2002 | 12:00 PM
Clayton's Avatar
Re: Re: Re: attempting first brake job this weekend...
I get my oil changed for free.
Old Jul 30, 2002 | 01:59 PM
John in Philly's Avatar
Your first mistake was going with cross drilled rotors in the first place, IMHO. They look nice but I know a bunch of people who ditched them 'cause of vibration, not to mention the fact that they can crack easier.
Good luck with the change.
Old Jul 30, 2002 | 03:07 PM
Maximajism94se's Avatar
just make sure u have lots o spare time...for me painting the things took forever cause i grinded off the rust 1st, etc...also make sure u have the right tools for your caliper pistons (which i'm sure u already have and i'm just wasting my breath ) like the half moon thingy and the other tool for the rear cause its diff....oh wait, ve 4 disk powah!
Old Jul 30, 2002 | 03:23 PM
pezking4's Avatar
what do you mean "about time"? Or was that directed at someone else
Old Jul 30, 2002 | 04:30 PM
mykizism's Avatar
lets not get cocky now
Old Jul 30, 2002 | 08:59 PM
JDwyer2821's Avatar
Re: Re: Re: Re: attempting first brake job this weekend...
I can do brakes with a blind fold on
Old Jul 30, 2002 | 09:05 PM
RosenKen's Avatar
Re: Re: Re: Re: Re: attempting first brake job this weekend...
Well... I can do brakes with sunglasses on.... in the dark!
One helpful hint, if you have a Dremel, get a wire wheel attachment and grind away any rust that has built up on the hubs (where the rotors mount on). Any surface that's not perfectly flat here will cause a vibration, and even a tiny bit of surface rust will do that!
Old Jul 31, 2002 | 08:11 AM
Clayton's Avatar
I know, I bought them because I thought they would look much better with my wheels, and they were decently priced, but I didn't know anything else about them. Had I found the org a little sooner I never would have bought them int he first place.
Old Jul 31, 2002 | 08:22 AM
Clayton's Avatar
Re: Re: Re: Re: Re: Re: attempting first brake job this weekend...
The dremel is one of the best tools ever made IMO. I was going to get some sort of wire brush or attachment to clean up my drums and calipers.
Has anyone ever used any kind of Rust Treatment spray? I was at Trak Auto yesterday and saw a couple cans of spray on rust treatment. Supposedly you spray a couple coats of this stuff on and it makes rust turn black, the can said "turn your rust into primer" or something like that.
I hope you mean the C-clamps, because I can't think of any other half moon shape tools.
Old Jul 31, 2002 | 08:34 AM
I've used it when I was doing some work on a beater Camry I used to have. It was ok for superficial surface rust but I would go with the dremel on the calipers, you'll probably get a better bond with the paint that way.
Old Jul 31, 2002 | 02:44 PM
Re: Re: Re: Re: Re: Re: Re: attempting first brake job this weekend...
i'm stoopid so i'm not sure what the tool is called, but its used to push in the piston on the front caliper...it has a screw thing attached to a metal piece shaped like a brake pad...ive tried using a couple spray-type products for getting off rust, but they all sucked...after many trial and error solutions to ridding of the rust, i found that nothing compared to a drill w/ a wire brush attachment...
Old Jul 31, 2002 | 06:42 PM
superdesi's Avatar
I recently moved to Manhattan, NYC....from Pennsylvania.
Does anyone know of a place where I could bring my car and work on it without getting a ticket from the police. I live in an apartment building and working on the streets is a no-no. All I need is nice clean flat ground surface.
I miss my driveway!
Old Aug 1, 2002 | 12:10 PM
Clayton's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: attempting first brake job this weekend...
yep - it's a c-clamp you're talking about
Old Aug 3, 2002 | 12:38 PM
Clayton's Avatar
I finished everything up a little while ago. Stock rotors and akebono pads are back on.
Everything went pretty smooth except I bent the **** out of a center ring and couldn't get it to fit back in.
What a difference. I will never get cross drilled rotors again. I couldn't believe how worn the EBCs were (must've been the x-drilled rotors)
Anyway - back to nice smooth brakes without vibration!
Old Aug 3, 2002 | 09:06 PM
avusblue92se's Avatar
rotor vibration
has any one else had this problem with cross drilled rotors from powerstop? if so i am going to have to cancel my order. i don't feel like dealing with vibrating brakes at all.
Old Aug 3, 2002 | 09:22 PM
pezking4's Avatar
Re: rotor vibration
I haven't used them but just the other day I was reading some archives and a lot of people were saying stay away from these. I think matt was telling someone not to confuse Powerslot with Powerstop because the Powerstop rotors are not high quality.
Apr 16, 2020 05:15 AM
RealityCheck
Oct 2, 2015 06:34 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
dshinn
Sep 26, 2015 08:07 PM
