Exhaust manifold studs bad?
I have a 1993 SE and I know that my flex tube on my stock y pipe is rotting and one of the rings around it has gone bad and is making noise but the noise is really bad. How do you know if it is your exhaust stud going bad? Im replacing the pipe at the end of august and also if it has to be replaced its probably going to have to be drilled out and how much does all that run to have done at a shop(replace y-pipe with warpseed pipe and replace exhaust stud?)?
thanks
-mike
thanks
-mike
Originally posted by nstymax93
where exactly am i looking on the manifold?
There should be 6 studs w/ nuts securing each manifold (there are 2, one in front, one in back). On the front it's pretty obvious to see the nuts. The rear, you might have to reach down there and feel it out. Just do it in the morning when the car is COLD!. The y-pipe will make a lot of noise (mine is busted right now) but a broken exhaust manifold stud will usually make a high-pitched whistle on hard acceleration.
OK, if the stud is broken will it make noise even after the car has warmed up? My car only makes noises when the car is cold but after abut 3-5 minutes of warming up ther are no noises at all. I know that once the pipe is hot it expands (right?). Hopefully its just the pipe and not the studs! Like I said, i know the flex tube on the pipe is rotting and the ring has come off and is rattling!
but some of that noise has to do with my flex tube rotting out and the ring thats there is jumping around too making some noise. Ill get it checked out when i get the new pipe put on
the cars not jusmping i mean the ring thats on the flex tube is vibrating making some noise and my flex tube is rotting. my manifolds are fine!
i was just trying to figure out if you can tell if they are bad or not!
you seems like in denial that the studs are broken...i say they are..but u say that some of the noise is from the flex. then go fix the flex...if u still hear it then you know the studs are gone.
if you don't know what you're looking at then when u get the flex done have the guy look at the manifolds too.
Originally posted by DanNY
let me flip on my supersonic hearing.
ballerchris510
Sep 10, 2015 09:35 PM
carid
Sep 9, 2015 05:06 AM
