Automatic window rolldown
Old Aug 8, 2002 | 11:44 AM
mtcookson's Avatar
On both of my cars, 1990 SE and 1991 GXE the automatic window rolldown switch doesn't work right. When i press it it rolls down like 6 inches then stops, then i press again and it does the same till i get it all of the way down. Here's the weird part, the switch will work absolutlely fine if it is hot outside... any ideas of what this could be??? Thanks.
Old Aug 8, 2002 | 12:48 PM
sdmcren's Avatar
I have had the same exact problem! Eventually my window would not roll up so I replaced the regulator. Even though it has been replaced I tend to have the same issue just not as severe..
Old Aug 8, 2002 | 01:39 PM
hoodank178's Avatar
Re: Automatic window rolldown
This happened to me too.I shot some contact cleaner into the switch and worked it back and forth a few times.Try that once or twice and see if it helps.It worked for me.You can get the cleaner at radioshack.
Old Aug 8, 2002 | 02:11 PM
mtcookson's Avatar
awesome. thank you!! i'll go try it.
Old Aug 8, 2002 | 10:21 PM
bbmax's Avatar
Re: Re: Automatic window rolldown
my window doesn't roll down at all.... but the thing is that when in push down the auto roll down button for a while... window rolles down all the way. when i let go of the switch, then it goes right back up. is this the regulator problem or the switch itself??
It holds down the window when i press the down button ... soon as i let go, goes right up.... press down on the down button, window stays in that position. very weird
Old Aug 8, 2002 | 10:27 PM
mtcookson's Avatar
sounds like maybe your switch is stuck in the up position which would be very bad. i would get that checked out very quickly.
Old Aug 9, 2002 | 02:13 PM
Lordrandall's Avatar
Did it work? Mine has the same problem.
Old Aug 10, 2002 | 09:53 AM
sublunary's Avatar
anyone know the best/cheapest place to get a replacement button for that? mine is weird. it works when i pop the button off and put it on backwards!
Old Aug 16, 2002 | 06:32 PM
91max180's Avatar
In my max, either the window does go down, or doesn't go down. Usually it doesn't go down at all, so I'm going to try that contact cleaner idea, and I'll let ya know what happens. Thanks.
Old Aug 17, 2002 | 03:11 PM
Aphrodisiac's Avatar
Same problem, I'm quite sure it's a result of pushing the button up for an excess amount of time. (trying to roll up the window when it's already rolled up)
I'm guessing the mechanics are just clogged and can't take the abuse.
Fbana41
Aug 29, 2016 12:18 PM
ef9
Oct 4, 2015 08:43 AM
lrb6805
Sep 24, 2015 05:03 PM
