Wheel Stud?
Wheel Stud?
Okay,
I looked in the haynes manual, and it show a picture that doesn't look like my car, and described a procedure that won't work. I can knock the stud out of the hud, but I can't get it out from between the hub and the place where that dust cover is. Any ideas?
There's supposed to be a cut-out place in the dustcover specifically for that purpose. You're supposed to be able to turn it so that the stud lines up with that hole and then knock it out that way.
However, I found that to be nearly impossible. I just bent the dustcover back with some needle nose pliers, problem solved. It's thin enough that you can just bend it right back afterward.
Re: hey jayson
Originally posted by darrick
do you still have the fan motors from your car?
Re: hey jayson
Andy29
Sep 29, 2015 05:32 AM
