Wacky Temp Guage
Old Aug 16, 2002 | 10:41 PM
rustangkilla
Wacky Temp Guage
89', 150,00 miles. I'll just be driving casually, not uphill, no AC, no nothing and the engine temp guage will go up ever so slightly, not enough to warrant pulling over but enough to notice. 2 minutes later it just goes back to normal. I'm thinking maybe just a bad needle or a bad thermostat. Any ideas??
Old Aug 17, 2002 | 06:51 AM
Sudesh's Avatar
I'm thinking coolant flush before replacing the thermostat. The needle seems to be workign fine, dont' mess with that. Check and make sure your fans are working.
Old Aug 17, 2002 | 09:25 PM
rustangkilla
How exactly would I test the fans?? I know they come on when the vents are blowing. Help.
Old Aug 17, 2002 | 09:53 PM
poorcollegeboy's Avatar
i dunno how a non-working fan would cause the temp needle to jump around but.... you can check your fans by unplugging the connection that goes into a silver cylindrical thing with two ac lines leading in/out it in front of the battery and jumping it with a wire. turn your car and ac on. the fans should turn when this is jumped. the silver thing checks for pressure in the ac system.
the needle will move down when the fan turns on. and will slowly move back up when the fans are off... once a certain temp is reached the fan turns back on.
also check the connections to the sensor for the gauge because it gets real dirty... it's located to the right of the front fuel injectors. it's the brass looking thing right in front of the red connector which is another temp sensor that should be checked and cleaned.
good luck.
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
msellas
Sep 23, 2015 09:16 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
