NEED HELP ASAP
Old Dec 15, 2000 | 12:41 AM
MidnightSpeed53
please help me
okay tonight i was working on my cars audio i have a 90 GXE and i was hooking up my amp to my front speakers then i put the deck back and the deck doesnt turn on the door lights dont turn on and now the seat belts are stuck
ive checked all the fuses and the wires no fuses are dead but my constant power wire is not working my ignition is though can someone help me this is bothering me cause i cant figure it out
please help ASAP
thanks in advance
Old Dec 15, 2000 | 02:27 AM
HoJo's Avatar
Did you unhook the battery? Just a thought.
Old Dec 15, 2000 | 04:42 AM
kaleb's Avatar
If you unhooked the battery, and you only put the ground cable back on the post without tightening it to the post, you'll have that problem. Be sure the terminal is securely fastened to the battery posts. That should fix your problem.
Old Dec 15, 2000 | 08:55 AM
MidnightSpeed53
nope
didnt touch the battery while doing this
Old Dec 15, 2000 | 09:14 AM
JeffesonM's Avatar
living out of a maxima...
Seatbelts and door lights won't work if something is f[_]cked up with the constant circut. Does the head unit turn on when the key is turned to the ignition position? It should, regardless of constant circut. Check to see if they're somehow wired together.
Old Dec 15, 2000 | 11:13 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Just give the car a jump start!!!!
this happen to me twice when I was doing audio work!!
Old Dec 15, 2000 | 05:09 PM
MidnightSpeed53
nope
i tried all these
okay well ive checked the wires the deck does not go on with the ignition turned on and i did try and start the car and nothing happened i also found out today that the outside lock thing is not working (that combination thing on the handle) other than its just the clock radio (but eq is working) door handle lights, seat belts( go up and down only when key is turned) and thats it other than that everything is normal i think its just the constant but i cant figure out what the hell went wrong cause i checked the wiring from the deck and it didnt touch anything at all and its even more wierd cause the ciggarette lighter is working hmmm someone wanna help me out here
Old Dec 15, 2000 | 06:27 PM
Foo90SE
Have ya tried unhooking everything you changed and putting it back to normal and see if stuff works again? if u do that and its all still screwed then something got fried probably. there are some fuses under the hood..u checked those? right by the battery, mounted on the inside of the fender. At least i think they're fuses..i may be thinking of a diff. car...
maxfever1987
Nov 19, 2016 08:01 PM
NewMax03
Oct 29, 2015 07:44 PM
MaximaRaj
27
Oct 2, 2015 07:31 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
chernandez1278
Sep 16, 2015 01:18 PM
