vg engine running lean help
Old Aug 19, 2002 | 10:32 PM
maximav6power's Avatar
pulled my plugs and the tips on all of them were white. I think the engine is running lean. I was told that you can clean the maf sensor if it is dirty. Is that true? What other possible reasons can it being running lean? I changed the o2 sensor already.
Old Aug 20, 2002 | 09:12 AM
eric93SE's Avatar
Having white spark plugs is actually ideal, were ALL of them white?. What else makes you think the engine is running lean? Does it have a miss?
You could check to see that the TPS (throttle positioning sensor) is adjusted properly, so that the closed throttle position switched is triggered at the correct rpm.
Old Aug 20, 2002 | 09:45 PM
MadMaxBrent's Avatar
Using a K&N panel filter on a VG can cause it to run lean.
MAXSE5SPD
Sep 17, 2022 04:00 AM
cruce91
Sep 20, 2015 10:23 AM
rtirbany
Sep 8, 2015 11:46 AM
Slamrod
Sep 3, 2015 07:38 PM
