Intermittent Engine Stall--Help!
Old Aug 20, 2002 | 01:57 PM
Jwats's Avatar
I have a 92 Maxima SE that has an intermittent engine stall--it has a severe hesitation for 2-3 seconds and then returns to normal. Sometimes, but rarely, it will come to a complete stop and then will restart. This occurs every half hour or so--but it is not predictable in any way. I replaced fuel filter and fuel pump relay which did not help...does anyone have suggestions? This is year 3 of the problem!
John
Old Aug 20, 2002 | 03:42 PM
Aaron92SE's Avatar
NWP Engineering.com
Re: Intermittent Engine Stall--Help!
What about a full tune up? Are you on top of all your maintenance?
Old Aug 21, 2002 | 01:26 PM
hooptey's Avatar
My 92 SE stalls every once in a while upon acceleration which is from a bad mass air flow meter. Idles real rough and everything. Another thing that will help is to change your ignition coils. THey are suppose to be changed every 50,000 miles. Mine have gone a little longer than that
Old Aug 22, 2002 | 10:06 AM
LegitMafiaBoss's Avatar
What are the symptoms of a bad MAF sensor and bad ignition coils? Or are they basically the same symptoms? I guess its cheaper to replace MAF then to replace 6 coils.
Old Aug 22, 2002 | 12:35 PM
sublunary's Avatar
when i first got my 92 se i had a stall problem. the idle was rough and would drop almost to zero when i put it in neutral and then would come back up. sometimes it stalled out. i did a tune-up and it runs like new! what i did was replace the plugs, air filter, fuel filter, changed the oil and added hp recovery oil treatment, used some fuel treatment and cleaned my throttle body out. all that combined to give me more power and a rock steady idle and no more stalling. sometimes you think a problem is just one thing, but it maybe a combination of little things that adds up. good luck
AaronL
Nov 15, 2020 11:52 AM
mikeg75
Nov 30, 2015 05:12 PM
RWCreative
Sep 21, 2015 11:01 AM
lrb6805
Sep 17, 2015 04:49 PM
johnaschon
Sep 14, 2015 04:29 PM
