Compression tester question for VE and maybe VGs
Old Aug 20, 2002 | 04:22 PM
Jeff92se's Avatar
I'm needing a caw
I bought an used tester that is your standard guage w/ the rubber hose and threaded connection(to the plug hole) But as you know on the ve, it has a deep socket to access the plug. There is no way I can tighten the threaded end to get a good seal. Do you guys know of a place to buy solid tube "extension" that I can thread into the plug hole and then attach the tester into that?
And are all spark plug thread sizes common? ie.. I don't have to buy some type of adaptor to fit into the Nissan VE sparkplug hole?
The usual Home Depot and run of the mill auto stores came up nada. I'll try to call a few tool places today. If I find something, I'll post up for others.
Old Aug 20, 2002 | 06:55 PM
poorcollegeboy's Avatar
Re: Compression tester question for VE and maybe VGs
http://www.mcmaster.com/
they have EVERYTHING. good luck. let me know how it turns out.
Old Aug 20, 2002 | 10:35 PM
Matt93SE's Avatar
STFU n00b!
check the threading on a plug (just buy an $0.89 ceapo Delco plug or something) and see what the thread on it is.. it's probably a 1/4" straight thread... same as a 1/4" npt, but straight cut instead of tapered.
which probably means you can have a 6,8,10,xxx" piece of 1/4 metal pipe threaded and it'll screw right into the hole.
Then again, I just got the rubber hose as tight as I could by hand with mine. that will be good enough to get a test on, as the cylinder raises pressure fast enough that a small leak around the threads won't mess up readings too much.
(Also be sure to do the measurements with the throttle wide open. it makes more difference in the readings than anything else.)
Old Sep 22, 2002 | 09:11 PM
Jeff92se's Avatar
I'm needing a caw
Just did the test w/ the tester I bought used. Fronts were 190ish psi all across and the rears were about 190-200ish all across. I didn't crack the throttle at all. Engine was cold. So looks like the compression is okay.
Old Sep 23, 2002 | 08:14 AM
nubiannupe's Avatar
OG Maxima.org Member
Hmmm... That's interesting, Jeff. I did a compression test on my cylinders just before tearing my car apart to put in a new fuel rail [all I can say about THAT little job is... ] and I had 175-180 psi on all six of mine (it's a VE, btw).
Old Sep 23, 2002 | 10:24 AM
SecretAsianMan's Avatar
Jeff92SE--
Not necessarily...
http://www.weekendmechanicsclub.com/...e-Mityvac2.htm
"1. Make sure the engine has been warmed up before beginning the test, to insure that the oil has been warmed up. A cold engine will not test correctly.
...stuff deleted...
4. Hold the throttle to full open position to ensure the engine gets adequate air intake.
...stuff deleted...
When the compression is found to be too high in one or more cylinders, this would be an indication of excessive carbon build up in the engine. This can only be corrected by performing a chemical de-carbonizing process on the engine (specialized service), or by removing the cylinder head(s) and physically removing the carbon that is attached to the cylinder portion of the head(s) and the tops of the pistons..."
--SAM
Old Sep 23, 2002 | 10:28 AM
Jeff92se's Avatar
I'm needing a caw
Hmm. I did the same test on my buddy's 4-gen warm and it came up with similar results but it's pretty easy to do the test again when warm. Thanks for the info. I was considering doing the water mist in the intake thing to clean out the carbon.
Old Sep 23, 2002 | 12:05 PM
Tarzan's Avatar
Jeff92se:
Keep in mind that your readings will be lower after extending the gauge pipe 'cause it encreased the volume of the cylinder. Not a great deal lower but still different from what you would have received from the stock gauge.
Old Sep 23, 2002 | 12:14 PM
Jeff92se's Avatar
I'm needing a caw
Na. I didn't use an extender. Just screwed in the stock hose as best I could. Hand tight was plenty good. Plus even with the extra volume, you can just keep cranking the engine until the compression tops off.
Originally posted by Tarzan
Jeff92se:
Old Sep 23, 2002 | 12:43 PM
One other important variable I'll mention is the actual calibration of the pressure gauge.
I not unusual to find low-end gauges that are off by 20 pounds or more. What you can do with an un-calibrated gauge is compare cylinder pressure differences but unless you know what the correction factor is, it can be difficult to conclude whether your engine is over- or under-pressure from factory spec.
There are several ways to check your gauge, I prefer cross checking it with a friend's high-end gauge. Another would be to find a friend with a brand new BMW or Porsche and offer to measure their compression and then compare your readings with the factory specs. However, don't forget to warm up their car before making the measurements. :-)
--SAM
Old Sep 23, 2002 | 12:46 PM
Jeff92se's Avatar
I'm needing a caw
I bought a new one from a parts store (cheapie one for like $40) But I tested some of the cylinders with both guages and they both read almost identical. So I think the guage is okay. Plus even if the guage was off, as long as it was consistently off, I could still be able to determine if one or more of the cylinders was doing something funny.
Old Sep 25, 2002 | 05:53 AM
Tarzan's Avatar
...which is unlikely to happen to Maxima. My mechanic's car is 92GXE and he put 550K on it. It drives and feels same as my own 93GXE with 90K.
Old Sep 25, 2002 | 08:46 AM
Jeff92se's Avatar
I'm needing a caw
Well the reason for this test was try to determine where my coolant is disappearing to. So naturally I was thinking HG. There's not that many ways a little bit of coolant can get into the oil. If you have any ideas, I'm all ears. I'm sorta stumped
Old Sep 25, 2002 | 11:51 AM
eric93SE's Avatar
Have you ever had the lower intake manifold gasket off? and maybe reused the original gasket?
Old Sep 25, 2002 | 11:53 AM
Jeff92se's Avatar
I'm needing a caw
I've had the lower one off but I used two new gaskets($$!). I tried to make VERY sure to put those on correctly. You never know though. I don't think coolant runs though it anyway. I know for 100% no oil runs though it.
Old Sep 25, 2002 | 11:57 AM
eric93SE's Avatar
Thats right I forgot.
Have you seen the setup that the FSM uses for doing a compression test? They have a long extension pipe that has a tapered rubber end that fits into the spark plug socket. It looks like its something that can be made on ones own, and then connected to a compression guage.
Old Sep 25, 2002 | 12:00 PM
Jeff92se's Avatar
I'm needing a caw
The one I used screwed in and it was fine. Probably better than the hold down type so you only need one person to do the tests.
How did the oil pump tests go??
Old Sep 25, 2002 | 12:05 PM
eric93SE's Avatar
I'm doing it this weekend, and I'm really looking forward to it
Old Sep 25, 2002 | 02:00 PM
maxdout92se's Avatar
hey, i'm losing coolant too and its not drippin from tha radiator...all i know is when i check at the end of the month, the lil ater container on the left side of tha radiator will be completely dry....but i don't have leak anywhere...
hopefully tha oil pressure test will prove your ideal correctly as to what happens to tha VTCs....can't wait for tha reuslts!!
aw11power
Oct 10, 2021 04:57 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
