CRZ Driver getting problems
I love going fast and I'm yes.. a crazy driver so to speak. Need to fix them problems so I can feel more assure going through does sharp curves, you know what I mean.
Here is the deal:
Everytime I finish making a sharp right turn and when the weight shift back to the center I hear this clunck sound from the front right side of the car . Furthermore, when there's more weight on the right it seems that the same spots sounds like it's vibrating. I get a little annoyed and was wondering if it's the bushings or the struts. My Max is lowerd with Eibach... and I sure hope it's not the cause of it.
Here is the deal:
on my 91 gxe it did the same thing somewhat. mine would also clunk when i went over my driveway or a bump. the bushings on the front sway bar were bad on my car. also, one of the engine mounts were bad and the mechanic (who wasn't really that good) said the bearings on the strut were bad. we just did the sway bar bushings and the problem was solved. (the bushings on the a arm thingy)
well... if i found the correct part it is 7.99 but i'm not sure. one thing to test to see if yours is doing the say thing as mine is to get a rod or a screwdriver, something to pry with, stick it under the sway bar on either of the a-arms and see if the sway bar moves. if it does the bushing thing needs replaced or tightened.
Sorry man, I have no mechanical knowledge...all I know is a screwdriver and the word help. What do you mean.... "stick it under the sway bar on either of the a-arms"????? Were is the sway bar located? What's an a-arm?
um... where the sway bar is mounted to the a-arm, try to push the sway bar up. if it moves at all it will probably need replaced. you'll have to try both side more than likely. i'll go get some pictures of what i'm talking about.
if the sway bar does move up and down you'll have to replace that bolt that holds it on the end. Your best bet is to run to autozone and ask them if they have it. More than likely they will have it and they should know what you're talking about. I forget how much it costs though, sorry.
MAXSE5SPD
Sep 17, 2022 04:00 AM
boomerbrian
Oct 31, 2018 10:25 AM
The Wizard
24
Oct 1, 2015 08:47 PM
