Rusted bolts please reply now
Old Sep 10, 2002 | 01:33 PM
maximalover's Avatar
Hi Guys
I am headed to dealer now. Last week I checked the front left wheel bearing..
Unfortunately all the bolts and nuts (19 mm on Caliper, 17 mm on knuckle, 17 mm on Ball joint) are rusted badly...
Mine is 93 Max SE. I leave in Michigan..Lot of snow, heat. Do you guys also have same rusted bolts... ? It was really bad...
I am planning to replace all of them.. The dealer is saying around $20- 30 (total).. Is it reasonable or can I get them some where else or cheaper ?
Old Sep 10, 2002 | 01:52 PM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Rusted bolts please reply now
Originally posted by maximalover
Hi Guys
wow..i saw the please reply now..since u demanded we help u.
$20-30 bucks in total for a few bolts that is a total beeeitch to get off..i think that's a good deal.
Old Sep 10, 2002 | 01:53 PM
karguy's Avatar
Hi Guys
I was at Pep Boys buying brake pads the other day and I walked by their nut and bolt display, it was really big. It might be worth it to check them out. Just a thought.
Old Sep 10, 2002 | 01:59 PM
Re: Re: Rusted bolts please reply now
Great to see your reply..
Now did you mean $20-30 for all the bolts (approximate) is a rip off
or a good deal.. ?
Pardon my understanding...
Old Sep 10, 2002 | 02:13 PM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Re: Rusted bolts please reply now
or a good deal.. ?
if they said..ok all the bolts $30 bucks.
i don't think that's a bad deal..that's assuming one wheel. better deal if it's a axle (front 2).
keep in mind labor rates are quite high at the dealer
Old Sep 10, 2002 | 04:41 PM
klymkow's Avatar
That's not a bad price. When buying these types of bolts/nuts, there is usually a material requirement/hardness/strenght and all that associated with them. NOT your standard off the shelf hardware.
You'll probably be wise to buy the bolt plate (has 3 studs on it)for the ball joints also. If the nuts are that bad, they will more than likely twist the bolt off. About $11 each - one for each side.
Are you also buying the 2 bolts and caliper floating bolts(?) that the caliper actually moves on? They will also probably need replacement. Make sure the calipers slide freely.
I usually apply a small amount of anti-seize to all bolts and nuts due to the salt that is used on upsate NY roads in the winter. Helps a whole lot! Covering with a good undersealer also helps prevent/slow down the corrosion.
Tim
Old Sep 10, 2002 | 05:17 PM
Dave S's Avatar
Definitely go with the factory nuts. The threaded hole is slightly out of round, so it acts as a locknut.
litch
123
Jan 4, 2024 07:01 PM
RealityCheck
Oct 2, 2015 06:34 PM
uttadms31
Sep 30, 2015 05:24 AM
