92 maxima NO Blinkers
Old Sep 15, 2002 | 08:34 AM
yeah right's Avatar
I have in my posession, a 92 Maxima. The interior (carpet/seats mostly) was very dirty. I pulled the front seats out, most of the center console(ie stereo/climate control/) and the console where the emergency break was, and the carpet. pic = http://home.swbell.net/lnx/05.JPG
Everthing went fine, until I noticed I had no turn signals, or emergency flashers. After some thought, I figured out that the emergency flasher button, had gotten wet, as it sits on a plastic frame, near the radio. Did this wet switch short circuit something? or, if it is just the blinker relay box, where is that? All my fuses are good, and I dont have an owners manual. Can anyonehelp?
Old Sep 15, 2002 | 09:05 AM
lophix's Avatar
Re: 92 maxima NO Blinkers
u probably pulled out the connection harness of the hazard light wheb you were messing with the console. plug it back in.
Old Sep 15, 2002 | 09:22 AM
yeah right's Avatar
Im pretty sure I plugged it back in
But i could be wrong, would that also affect the blinkers? not just the emergency flashers? I hate to tear it all apart again, especially just to find out that its plugged in.
Old Sep 15, 2002 | 09:24 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
if i recall correctly, your blinkers won't function if the switch is unplugged or not working...
lophix's Avatar
Re: Im pretty sure I plugged it back in
yup. i guarantee you.
Old Sep 15, 2002 | 10:28 AM
«§»Craig B«§»'s Avatar
all you have to do is remove the trim around the radio and climate control area to check; that should take less than 5 minutes
and like lophix and Chris said, your blinkers will not work when the hazard switch is not plugged in
Old Sep 15, 2002 | 10:45 AM
yeah right's Avatar
You were right !!!!
Thank you, the switch was unplugged. now i can actually get the car inspected, and drive legally. Thanx for all the help.
Goffery2uned
Aug 21, 2015 09:50 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
