Engine Stalling When Coming To A Stop
Old Sep 18, 2002 | 06:40 AM
SCOTTFISH's Avatar
Well, I feel like I have crossed this path before. I had a problem with the rpms dropping down and almost choking my 93 se out when coming to a stop and putting the clutch in. I reset the idle and it seemed to fix the problem. Now, when I come to a stop at a red light or slow down to make a turn with the clutch in, my car will stall. Of course, my power steering goes when the motor quits. Does anyone know what could be the problem. Could it be the pcv valve? I had the o2 sensor replaced a while back. Could it be the ecu?
Old Sep 18, 2002 | 09:05 AM
Chris Gregg's Avatar
Get Off My Lawn
What all did you adjust?
Idle position sensor, AAC valve, timing? Where are you located, TN?
Old Sep 18, 2002 | 12:26 PM
medic's Avatar
belts? lose or slipping belts can cause you to lose power like that too
Old Sep 23, 2002 | 05:26 AM
asta1800's Avatar
Re: Engine Stalling When Coming To A Stop
i seem to have same problem with my 92 maxima what can be the problem?
Old Sep 23, 2002 | 12:09 PM
Ekote's Avatar
Re: Re: Engine Stalling When Coming To A Stop
lol, I have the near-exact same problem, though my car doesn't stall when making corners. I thought it might be a fuel problem, but injector cleaner and a new fuel filter have done nothing.
Old Sep 23, 2002 | 12:30 PM
asta1800's Avatar
according to one mechanic that i spoke to it may and he thinks it is the exhaust gas recirculation valve which is stuck and not functioning properly???????? does anyone have a comment on this diagnosis-thanks
Old Sep 23, 2002 | 01:18 PM
SCOTTFISH's Avatar
Can anyone tell about this exhaust gas recirculation valve? where is it located and can it cause the car to stall?
Old Sep 23, 2002 | 01:45 PM
Jeff92se's Avatar
I'm needing a caw
Re: exhaust gas recirculation valve
"S" to the..."E" to the..."A" to the.."R" to the.. "C" to the.. "H"!
http://forums.maxima.org/showthread....culation+valve
Just the slightest amount of effort got an answer. Alot faster too.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
kirkhilles
Aug 8, 2015 10:53 AM
