Who happens to know where is the oxygen sensor located on a 90 maxima
Old Sep 25, 2002 | 01:35 PM
hatetrouble's Avatar
Who know the location of the oxygen sensor, or called exhaust gas sensor, on a 90 Maxima?
Thanks.
Old Sep 25, 2002 | 01:43 PM
shock211's Avatar
Re: Who happens to know where is the oxygen sensor located on a 90 maxima
should be right at the connection between your maf and air box. just open up your air box and remove the filter. you should see it.
Thanks.
Old Sep 25, 2002 | 01:45 PM
5spd92SE's Avatar
Thanks.
It should be just before your Catalytic convertor.
Old Sep 25, 2002 | 02:20 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
it's located on the passenger side of the Y-pipe just before the cat
Old Sep 25, 2002 | 03:53 PM
ocMax's Avatar
Just to clear up the confusion. . . . as far as i know there are 2. one on the y-pipe and 1 just before the cat. You will see them sticking into the pipe.
Old Sep 25, 2002 | 04:00 PM
Jeff92se's Avatar
I'm needing a caw
Good lord. I was just gonna leave the question to the newer guys so they could help the other newer guys but damn! As Chris said, it's on the Y pipe just before the cat.
Now:
1) IT'S NOWHERE NEW THE INTAKE SECTION OF THE ENGINE!
2) 3-GEN MAXIMAS HAVE ONE 02 SENSOR!
Old Sep 25, 2002 | 04:34 PM
maxdout92se's Avatar
i was about to call on jesus myself wit all those answers...saved by tha moderator again!!!
Old Sep 25, 2002 | 04:47 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
i can't believe some of these replies
Old Sep 25, 2002 | 05:20 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
you do get the best exhaust gas reading in the intake tract though...its a known fact!
Old Sep 25, 2002 | 05:22 PM
DanNY's Avatar
Ad·min·is·tra·tor
i believe on CA spec models there are two sensors.
one that's actually the O2 and one is the exhaust gas temp.
just to clear things up.
Old Sep 25, 2002 | 05:30 PM
ocMax's Avatar
Thank you very much
Old Sep 25, 2002 | 05:47 PM
I expect some convincing replies, better give some figure.
Anyway thanks to all replies!
Old Sep 25, 2002 | 06:11 PM
DanNY's Avatar
Ad·min·is·tra·tor
Originally posted by ocMax
Thank you very much
before u break out the bubbly the O2 sensor is on the Y-pipe but it's right infront of the cat...harness is clipped to the rear engine mount.
the other sensor is NOT the O2 sensor..it's the exhaust gas temp sensor.
keep in mind the orig poster asked about the O2 sensor/oxygen sensor.
so u get 1/2 credit..but u get 1/2 that deducted because u tried to confuse everyone with the exhaust temp sensor being the 2nd O2..which is not the case.
for all u Fed Emission guys with the bible (FSM) that wants to know what i'm taking about...
EF&EC section
page 116 (or somewhere around there page vary w/ yr of FSM)
hate: your answer is there's one oxygen sensor. it's located infront of the cat on the Y-pipe itself. it sticks out to the passenger side with 3 wires attached to it. the other end of the wire goes to a harness that's grommet into a small hole on the rear engine mount.
i dare anyone else to correct me on that. BRING IT!
Thanks!
Dan
Old Sep 25, 2002 | 06:24 PM
Dan, thank you very much.
Old Sep 25, 2002 | 06:29 PM
slomatt's Avatar
Man, I feel helpful today.
- Matt
Old Sep 25, 2002 | 06:36 PM
Man, cool! thanks, Matt.
DanNY's Avatar
Ad·min·is·tra·tor
Re: Picture
- Matt
LOL...wow he helps out once in a while.
Old Sep 25, 2002 | 08:19 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
Thank you very much
*buzzer*
mrc00l88
Jan 25, 2024 01:14 PM
kjlouis
Nov 24, 2018 06:09 AM
