Rear strut "gland nut"
Old Oct 15, 2002 | 09:23 PM
todamax's Avatar
I'm in the middle of doing a strut job on my 89. THe car had 140K on it and I think the struts have never been replaced.
Anyway, the fronts went fine - the rears are a PAIN! I did my 93, and didn't have any problems that I needed help on. It wasn't impossible seeming.
I cannot get the "gland nut" off. Its permarusted to the insert holder. I had a shop tell me to just cut the top off, the inserts are designed to be smaller and the insert holder is threaded like 3 inches down. Does this sound familier to anyone?
Ryan
Old Oct 15, 2002 | 09:36 PM
«§»Craig B«§»'s Avatar
Re: Rear strut "gland nut"
you shouldn't have to do any cutting and I would avoid that if at all possible
get a vice to hold the base of the strut and get a big pipe wrench to try to get the gland packing nut out
Old Oct 16, 2002 | 06:02 PM
todamax's Avatar
Yeah, I've done what I can to get the nut off. Big pipe wrench, air chisel, heat, etc. The Nissan dealer told ne to buy a new holder.
No one elses has rusted like this huh?
Old Oct 16, 2002 | 06:53 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
vice, breaker bar and liquid wrench...rust or not it will pry loose w/ enough force
Old Oct 17, 2002 | 07:22 AM
MaDMaX024's Avatar
or if its rusted enough, it'll break......
Old Oct 17, 2002 | 07:52 AM
DanNY's Avatar
Ad·min·is·tra·tor
but it's not rusted that much..remember there's a rubber boot around that part.
if that breaks then break out the dremel and you'll be fine.
try getting it off like this..
clamp the assembly to the vice
set pipe wrench on it..or get the right tool/socket/wrench
either hammer or slide big breaker bar over tool and crank down.
helps to have someone stablize the vice...it's hard to get off..but it'll move with some work.
go eat your wheaties.
Old Oct 17, 2002 | 08:26 PM
b2cute69's Avatar
nut
yeah same thing happened to me well i put the strut pipe on a flat surface and hit it all around evenly and it came loose , if you f**** it up i have a whole strut to sell you.
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
dvcamp
Sep 18, 2015 10:17 AM
ef9
Sep 5, 2015 11:18 PM
Johnny9595
Sep 3, 2015 05:18 AM
