Reinforcing the Rear Sway Bar Mount
Old Oct 17, 2002 | 02:32 AM
70KSE's Avatar
I want to reinforce the upper rear sway bar mount before I install a ST sway bar set.
Is it possible to reinforce the bracket without having to hot weld a new bracket in? Like cold welding some heavy duty washers to the insides of the brackets with JB Weld. Would this be strong enough, or is heat weld the only way to go?
Also is it unsafe to drive the car without a rear sway bar installed?
Old Oct 17, 2002 | 06:13 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Reinforcing the Rear Sway Bar Mount
take into account how heavy the car is and how much that weight leans in a turn....
now..
yes it's possible to reinforce the bracket..but YOU MUST WELD or use another mechanical mean to reinforce it.
heavy washers will only be as strong as the weld to the frame.
JB weld is not going to do it here...it may patch a hole in your oil pan..but no way in he11 it's going to stop a 3000lb+ car from leaning.
Old Oct 18, 2002 | 05:57 AM
maxmizd27's Avatar
Mine each broke twice and they WERE welded. The one side doesn't even have the factory bracket anymore. A new one had to be made.
Old Oct 18, 2002 | 07:09 AM
male's Avatar
When I get the rear Addco bar, I'm going to invest in a little mig or arc welder and get creative. I've looked at for a while, they seem pretty flimsey. They generally pull out of the frame right? Does it break anywhere else?
lowpost99
Oct 26, 2025 06:53 PM
matts95max
Apr 23, 2025 10:44 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
doctorpullit
Sep 10, 2015 06:33 PM
