what year 300zx calipers fit?
Old Oct 17, 2002 | 12:00 PM
nstymax93's Avatar
I have a 93' SE and I want to upgrade the calipers in the front and wanted to use 300ZX calipers. What year 300ZX should i use the calipers from that would fit on my stock size rotors? Also does it matter if its a turbo 300 or not? I think i heard it has to be milled down 3mm too. Not sure. Any help is appreciated.
-Mike
Old Oct 17, 2002 | 02:47 PM
nstymax93's Avatar
bump
Old Oct 17, 2002 | 03:05 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
I think the z31 rotors are what you want, I know for sure the z32 won't fit...not too sure about the differences between turbo and non. try searching though, theres plenty info!
Old Oct 17, 2002 | 03:26 PM
mtcookson's Avatar
http://forums.maxima.org/showthread.php?threadid=149757
Old Oct 17, 2002 | 04:48 PM
avusblue92se's Avatar
just make sure you get newer 300z calipers(after 92 i think) they were the same for both turbo and non. you will need to mill down 3mm rrom the RADIUS of the rotor. also make sure your offset of your wheels are suitalbe for the calipers, or you will need spacers. there are directions on maximadriver.com. there are a few other smal details. email me if you have anymore questions.
Old Oct 17, 2002 | 07:50 PM
4signs's Avatar
Re: what year 300zx calipers fit?
-Mike
I have a 93se too, and im using 93 z32 calipers and 12.5" vr4 dill/slotted rotors. Try to get 91-94 300zxtt calipers, after 95 nissan change the calipers from aluminum to iron (tried to cut cost)I believe the na calipers are a little different and the rotors for the na are like 26mm, and the turbos are 30mm wide. I changed to 300zx ss lines our cars have banjo fitting, but I believe you can use the stock lines if you use some crush washers.
BkGreen97
Apr 2, 2016 05:47 AM
captchaos
Mar 15, 2016 12:18 PM
mclasser
Sep 6, 2015 09:05 AM
GregL65
Sep 5, 2015 09:37 PM
