Tires!!
Old Oct 18, 2002 | 03:42 PM
SupaMax's Avatar
Tires!!
Hey someone help real quick I just ordered 4 brand new Dunlop High Performance ALl seasons. I ordered it 205/60 that size will fit still right I figured so because i have 205/65 on mine right now. Just write something back to make sure for me thanks.
Old Oct 18, 2002 | 04:48 PM
Onemax's Avatar
Re: Tires!!
Sure it'll fit.
Old Oct 18, 2002 | 05:57 PM
XMP1975's Avatar
Re: Tires!!
Yeah it'll fit. It'll give a lower profile and possibly alot better handling and cornering.
Old Oct 19, 2002 | 01:12 AM
Agamemnon's Avatar
Since your 205/60 tires' diameter is slightly smaller than the original, your speedometer will be inaccurate. You'll be actually going slower than the speedometer tells you. You will get slightly better acceleration due to the smaller wheels, but also lose a bit of fuel economy. And as XMP1975 said, you'll get slightly better handling and slightly harsher ride because shorter sidewall = stiffer sidewall.
Old Oct 19, 2002 | 04:25 AM
nubiannupe's Avatar
OG Maxima.org Member
Ok, here's where I'm confused. I thought the formula for tire sizing went like this:
205/60/15 - (only used 15 as an example)
205 = width of the tire across the tread
60 = aspect ratio (height of the tire from where the rim meets the tire up to where the tread meets the road)
15 = tire diameter
With that being the case, how do we know what diameter tires SupaMax is running if he didn't say it? All I see is the width and aspect ratio.
Old Oct 19, 2002 | 11:11 AM
Agamemnon's Avatar
THe height of the sidewall (hence the overall diameter of the tire) is the tire width (in this case 205) times the aspect ratio (60, meaning 60%). 15" is the wheel (rim) diameter. So the diameter of a 205/60/15 tire should be: (205 x 60%) x 2 (for both top and bottom sidewall) + 15". I think the 205 is in mm (millimeter).
So as you can see a 205/65/15 tire (original size) is slightly larger.
Old Oct 19, 2002 | 11:13 AM
SupaMax's Avatar
size
of course im still with my stockies because im getting some nice chrome rims in the winter for spring jus need these now to survive in the winter.
Old Oct 19, 2002 | 03:20 PM
nubiannupe's Avatar
Ok, let me see if we're both on the same sheet of music:
The first number is the width of the tire in millimeters, measured from sidewall to sidewall. To convert to inches, divide by 25.4 In the example above, the width is 185mm or 7.28".
The second number is the aspect ratio. This is a ratio of sidewall height to width. In the example above, the tire is 7.28" wide, multiply that by the aspect ratio to find the height of one sidewall. In this case, 185x0.60=111mm or 7.28"x0.60=4.36".
The last number is the diameter of the wheel in inches.
To figure the outside diameter of a tire, take the sidewall height and multiply by 2,(remember that the diameter is made up of 2 sidewalls, the one above the wheel, and the one below the wheel) and add the diameter of the wheel to get your answer.
Example...185/60/14
185mm x .60=111mm x 2=222mm + 355.6mm(14")= 577.6mm or 22.74"
(quoted from here!)
This was what I go by when figuring that stuff out. So, the bottom line is, yeah SupaMax... they'll fit.
Then, WTF am I doing here??
Old Oct 19, 2002 | 07:00 PM
Pervis Anathema's Avatar
I ran a 225/60 on my stock rims for over a year. I just switched to a 225/50 and they work fine also.
Old Oct 20, 2002 | 12:00 AM
Agamemnon's Avatar
Nubiannupe, isn't that exactly what I'm saying?
Old Oct 20, 2002 | 06:20 AM
nubiannupe's Avatar
I know... I just felt like post whoring today.
Old Oct 20, 2002 | 07:11 PM
jwhite's Avatar
Just put the damn tires on. So what if your speedo is a little optimistic, or your fuel economy suffers (probably so little it'll be unnoticed).
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
