2-3 cutloose 89 maxima
Old Nov 11, 2002 | 05:46 PM
jbenn's Avatar
I am having a 2-3 cutloose problem on my 89 Maxima. I removed the outer 2-4 accumulator spring to help the 1-2 shift and drilled the two holes in the plate to the recommended size by ATSG. The 1-2 shift and 3-4 shifts and all downshifts are fine. Just when you think the trans should shift from 2nd to 3rd, 2nd falls out and 3rd comes in, but very delayed and get some rpm increase before 3rd actually applies. It doesnt seem like a slip, but more of what they call "cutloose". Has anyone had this problem or do you know anything to try? All help is greatly appreciated.
jbenn
Old Nov 11, 2002 | 10:39 PM
Matt93SE's Avatar
STFU n00b!
have you replaced the clutches yet? sounds like 3rd isn't engaging fast enough. worn clutches or low line pressure to the 3rd gear solenoids could be a culprit.
Old Nov 12, 2002 | 06:09 AM
jbenn's Avatar
No I haven't replaced clutchs yet. The thing had planetary 6,000 miles ago. I replaced planetaries all seals. All clutch lining were excellent and cearances were within tolerances. I read in some of ATSG's stuff that the line pressure solenoid is usually the culprit of 2-3 cutloose. I am going to try to put a gauge on it tomorrow and go from there. What do you think? Thanks for your reply.
jbenn
Old Nov 12, 2002 | 06:36 AM
male's Avatar
jbenn
I think auto trannies suck *****. Especially one's that have been f'd with. Knowing the fragile nature of 3rd gen auto's, I give you props for being brave enough to try anything on it!
halfpol
Oct 17, 2022 12:16 PM
Goffery2uned
Aug 21, 2015 09:50 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
