Bose Relay question
Old Nov 12, 2002 | 11:49 AM
nickschu's Avatar
Bose Relay question
i know there are quite a few threads regarding the Bose system. i seem to be having the same problem where the one speaker works all the time, but the other 3 work only intermittently. i read the thread regarding fixing the relay, but i don't think i found the correct relays. where is the relay? under driver side dash? under passenger dash? i found 3 relays under the driver side, but unplugging them had no effect on the stereo. where do i need to look?
Old Nov 12, 2002 | 09:23 PM
John van de Pol's Avatar
The Bose relay is not under the dash, but behind the kick panel on the driver's side. If one Bose speaker still works ok, the problem is not likely to be the relay as it switches ALL the Bose amps. Most likely capacitors going bad in your Bose amps.
John
Old Nov 13, 2002 | 08:44 AM
nickschu's Avatar
Thanks for the info. any chance anyone knows how to fix them? or how much it would cost to replace them? thanks again.
AaronL
Nov 15, 2020 11:52 AM
Mar 12, 2020 12:06 AM
popdedop
Sep 11, 2015 11:17 AM
