What is the best way to remove a GOOD exhaust manifold stud?
Old Nov 14, 2002 | 08:34 AM
5spd92SE's Avatar
Since Chilton's sucks...
What is the best way to remove the GOOD (non-broken) exhaust manifold studs on the front side of the engine? Vicegrips?
I really dont want another broken stud if it can be prevented. Please help. I am replacing them all. Thanks!
Old Nov 14, 2002 | 08:48 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: What is the best way to remove a GOOD exhaust manifold stud?
best way...
slide two nuts over the threaded part.
use two box wrenches..back out the 1st one while holding the 2nd one. they will jam together and if it's possible it'll come out in one piece.
or if the threads are shot to sheeeit..get a stud remover...kinda clumsy tool but it might do the trick.
Old Nov 14, 2002 | 11:01 AM
5spd92SE's Avatar
Re: Re: What is the best way to remove a GOOD exhaust manifold stud?
Originally posted by DanNY
best way...
Thank you. I will give a shot.
Old Nov 14, 2002 | 11:03 AM
Jeff92se's Avatar
I'm needing a caw
I just some vice grips. But I also had a stud remover. It's a little large but works well w/o chewing up the stud. They aren't very tight.
Old Nov 14, 2002 | 11:12 AM
5spd92SE's Avatar
...and installing the new studs?
Cool thanks. I am assuming that the "extra nut" trick would work for the install of the new studs? True?
Any idea on the Torque figures of the new studs going into the head?
Chiltons lists the nut at 13-16, I would imagine the new stud to be around that, maybe a little more.
Old Nov 14, 2002 | 11:15 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: ...and installing the new studs?
not too tight..use anit sieze in there too.
Old Nov 14, 2002 | 11:16 AM
Jeff92se's Avatar
I'm needing a caw
Yeah, a little ghetto but it should work. That torque sounds about right(for an aluminum head). I suggest a little loctite(med strength at most)
Old Nov 16, 2002 | 04:22 PM
Nismomaxt's Avatar
VERY IMPORTANT! Drench that stud in liquid wrench and let it soak for a while! Trust me.
JRod28
Dec 29, 2023 09:56 PM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
vingodine
45
May 21, 2016 12:46 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
george__
Aug 18, 2015 07:06 PM
